will a gtx 480 fit in my case
1 Jan 2007
Hi ,
i currently have a bfg gtx275 fitted in my antec 300 case which is a bit of a tight fit , now i'm looking at getting a POV GTX480 , i've looked around the tinternet and can't find any sizes listed for the GTX480 , does anybody have one or know of the size differnece between the two cards ? dont really want to upgrade my case as well at the moment :confused:
Hi ,
480s and 275s are both 10.5 inches long according to NVIDIA - click the specification's tab, here and here.
As a side note, this question pops up again and again, for any amount of case/card combinations, and Googling doesn't always reveal the answer. So, would there be any interest in a thread listing card lengths and available space in specific cases?? Just a thought!
480gtx isnt any bigger that 275gtx so it should fit no probs?
The real question is if this eol toaster will run on your psu?
And have u got enough airflow to keep it cool.
Hi ,
480 in my Antec 300 right now, Bags of room :)
Definitely; when I got my GTX280 I had to remove one of my Chieftec Dragon HD cages so now it is just sat loose in the bottom of the case.
