- 28 Apr 2010
- Newcastle Under Lyme
Hi i was just wondering if anyone could tell me what software to use to overclock this card, its factory overclock is 875Mhz!
MSI Afterburner.
Yup, I run my Asus 5770s at 1000 core clock
Voltage Tweak editions, although probably the same board as yours.
Memory on these cards is good for around 1280-1300, any higher and it begins to lower performance drastically.
What cooler do you have on yours? The egg shaped cooler or the more common blower HSF which draws heat out side of the case?
What temps you getting with the 1000Mhz overclock??
