4 gig or 8 gig and how will a new GPU affect this?
233
233
21 Nov 2004
Wishaw
right guys,
been playing about with my rig
spec
Q9450 @3.45ghz
8gig xms2 ram pc6400 running at 430 fsb 2/1
Corsair TX650
currently an 8800 gts 640 with a 6970 enroute atm
questions
what is going to give the overall better system
i can run the cpu at 3.6ghz if i drop to 4gb ram so its
3.6ghz/4gb ram or 3.45ghz/8gb ram
and does the memory on the graphics card affect system memory i vaguley remember something about video memory being deducted from system memory or perhaps thats the beer talking
thoughts pls guys
win7 64bit
any thoughts on the graphics card question?
as the 6970 runs 2gig of video memory
Assuming you're on 64-bit then the memory on gpu will not affect system memory.
RE the rest of it, knowing what the main uses are might be helpful!
4GB is generally considered "enough" for gaming, but 8GB is more suitable for encoding/editing.
Usually when people talk about video memory affecting system memory is when someone have a 32-bit (rather a 64-bit) OS. In which case the roughly 3/4GB of accessible memory is taken from the video memory, so even less system memory is accessible.
You will be fine running 8gb and the gpu without any problems :)
but what would be better ?
8gig and cpu at 3.45 ghz or 4 gig and cpu at 3.6ghz or is there going to be no noticable difference?
I'd be inclined to go for 3.6Ghz.
You'll get more frames and more min fps than you will with the 8GB and lower clock as more often than not a chunk of that 4GB ram will not be used - so with 8, you've just got even more not being used.
There won't be any massive noticeable difference, but the higher clock will most likely result in a 2-3fps boost to your minimums.
Sorry, the extra memory will probably help with photoshop ect and the performance difference I suspect would be minimal.
hmm food for thought,
seriously tempted to keep the 8gig and go for a 4gig ram drive
Hope you don't mind me asking a question in relation to what the OP said. :)
Why is it that dropping from 8gb of memory to 4gb makes it easier to overclock the cpu? I have heard this before but don't know the answer.
I believe it's to do with the extra stress on the Northbridge on the motherboard, as sometime you need to increase the Northbridge (MCH) voltage to assist.
Hopefully some one can confirm :)
