There has been controvery over the image quality with AMDs default settings. Are reviews comparing these cards against each other on an equal footing?
AnandTech's review says "Finally, all tests were done with the default driver settings unless otherwise noted." Does that mean they're using a lower quality AMD setting even when they set each game in the test to maximum quality?
Here's a link to AndanTech's quality comparison image. Highlight the 3 graphic cards under the black and white image to see the picture change. Do you notice a difference in quality between the 480 image and the 6800 image?
Please don't turn this into a fanboy slagging match, if you have any good evidence of where IQ does or doesn't exist I'd be interested to see it.
Thanks
Thanks
