battery care- some easy questions.
30 Nov 2005
Got any tips on battery care?
Is it better to drain it down every time rather than start charging half way through discharge?
when on AC do you a have to remove battery?
Is it better use on AC if you have the chance to?
any other tips?
These are my notes I generated when researching the same topic:
Prolonging a laptop battery
- Using AC power mains
o Remove battery when running AC (due to heat)
- Charging
o Try and avoid charging past 90% and discharging below 20%
 Shutdown laptop when charging to cool
- Extend life
o Avoid exposing the battery or the laptop to excessive heat
- Storage
o Stored at 40-50% capacity in a cool, dry place such as a cupboard
- Run-time
o Switch off LAN/WLAN/Bluetooth if not needed
o Turn off unnecessary devices
o Turn monitor off when not in use
My view is just use it. Ive had some batteries die in months and some last years. So ive come to the conclusion just use the laptop how I want to use it.
Worst thing you can do is leave it in your car in this kind of weather - the temperature really affects the battery and can hurt it long term.
Best thing you can do is leave it in your car in this kind of weather - a high temperature really affects the battery and can hurt it long term.
Fixed... ;)
Obviously remembered that wrong then! :p
Thanks for the table/image, I think that must be the exact thing I saw a while back. :)
