does anyone have any info on Nvidia and AMD's dual gpu cards ?
dates specs etc etc
becuase i have a feeling heat is going to be an issue
i will have to put the cards right on top of each other with mm's between them
Just curious...anyone think dual-GPU card is a bad idea, unless with a very good air-cooler or watercooled?
I always thought that dual-GPU graphic card would have shorter life-span than single GPU card because of the heat, as I think we have already seen lots of 4870x2 borked before even hitting the 2 years mark.
While Crossfire/SLI do draw more power, I think with a decent airflow case, and a wide enough gap between the two cards it would keep the GPUs cooled better...at least it wouldn't be having two GPUs taking a sauna together on a single PCB
What do you guys think?
