- 1 Oct 2007
- Hawkes Bay , NZ
I use it every time,due to tesco being closer to me.My mpg has droped to 24-25mpg in the last month,from 27-28 in the summer months.
).Is it worth a shot at the next tank?
[TW]Fox;18046984 said:It is obviously the case that if you do short trips, the cold weather will hamper your economy because the car takes longer to warm up and so a greater percentage of your journey is without the engine at optimum temperature.
But once the engine is up to temperature, I've always wondered what the effect on MPG is. Can somebody technical answer? If you were to drive 200 miles at 70mph with a warm engine when it's 20c, and then again when it's -1c, would there be an economy difference?
Try several tanks - you need to give it time to adjust.
.[TW]Fox;18046984 said:It is obviously the case that if you do short trips, the cold weather will hamper your economy because the car takes longer to warm up and so a greater percentage of your journey is without the engine at optimum temperature.
Seems to make a big difference in my 197, i didnt want to believe it, but it does, and the people on some of the clio forums recommend using it too,
Ok not many can/will know how to do thatNot really.
Every time I change my fuel or suspect my driving style is going to significantly change I do a manual hard reset on the ECUs. Usually everything adjusts itself nicely within a couple of miles.
