Will OCUK do Sandybridge Pre-Overclocked Bundle?
Core i7 2600k bundle @ 4.9GHZ
featuring
core i7 2600k
asus sabertooth p67
corsair vengeance 2133mhz
corsair h70 cpu cooler
please i beg you, especially the motherboard, its tactical vest makes me all fuzzy inside, and from what i have been reading its the highest durability mobo out there, its testing means it has to go thru temp cycles 5 times which range from -40c to 90c ! :O military grade mobos 4tw?
if webbys are already reporting 4.5ghz, then we should hopefully see ocuk doing them bundles. :)
Didnt like the previous Ocuk bundles with the amount of overheating/stability issues I reckon 4ghz was just too taxing for the old Core i7s, anyhow id be happy with just the Core i7-2600 turbo boost feature @ 3.8ghz. I think though if its running at 3.4ghz then 4ghz+ will be a breeze.
I think they will both be pretty equal to be honest. The main difference is the number of theads, clock speeds and L3 Cache. Unless you are on a real tight budget I don't see much reason not to go for the 2600K and clock it.
We will have a full range of systems and OC bundles ready for launch date!
Aaarrgghh! Glad i seen this post!!
i was just on the verge of hitting the button one of the Krypton bundles but i'd be mad not to wait a little longer to see what you guys can throw at us with Sandybridge.
Hoping for a nice bundle for around the £600 mark;)
Roll on January 9th:)
I would seriously be expecting a decent Sandy Bridge bundle for about £400.
Considering Phenom II X6 bundles can be had for between £300-£400.
The other thing is that most of us probably already have DDR3 memory and therefore would only need motherboard/cpu.
So a Sandy Bridge motherboard/cpu for under £300 would be welcome.
