Yes - that should draw around 320 watts (i.e. no more than 27 amps on the 12v rail). Even the power thirsty 480 GTX and i7 can be run on a decent 400W PSU.
If a GTX480 + i7 can be run of a descent 400watt PSU and you saying my system draws about 320watts, a 4.2GHz i7 920 draws about 150watts by its self. So why do OCUK use a 600watt PSU in the Titan Onyx" Intel Core i7 950 3.06GHz @ 4.00GHz Quad Core DDR3 System with the option of a GTX480 or the Titan Xenomorph" Intel Core i3 540 3.06GHz @ 4.20GHz Nvidia Edition DDR3 System a 600watt PSU and the option of a GTX480 and again not a 400watt?
Its simple the 400watt for example the CX400watt + 30Amp on the 12v rails, would not have enough WATTS + AMPS to run either System.
pcanywhere > "Yes - that should draw around 320 watts (i.e. no more than 27 amps on the 12v rail). Even the power thirsty 480 GTX and i7 can be run on a decent 400W PSU.
So your saying a CX400watt + 30amp 12v rails would run my system as it only draws about 320watts + 26amps , my i7 920 4.2 draws about 150watt alone and my GTX470 at 840/1700/2000[ about a 46% overclock] will draw close to a GTX480.
Hardwarecanucks.com review > Even the GTX580 based system would need a 600watt PSU example CX600watt + 40Amp on the 12v rails -
http://www.hardwarecanucks.com/foru...s/37789-nvidia-geforce-gtx-580-review-21.html > We would recommend a good 600W PSU for this card nonetheless
Techspot review -> their test system i7 3.7GHz[700watt PSU] + 480 is drawing over 500watts.
http://www.techspot.com/review/263-nvidia-geforce-gtx-480/page13.html
EXtreme Power Supply Calculator Lite v2.5 > my system needs a Minimum PSU Wattage: 619 Watts, but in my 4th post l quoted a GTX470 > 550watt at least 35amps for a average sYstem, my system is not average.
Guru3D review of the GTX470 GPU 470 -
On your AVERAGE system the card requires you to have a 550 Watt power supply unit. We recommend AT LEAST 35 Amps in total available on the +12 volts rails (accumulated).
At pc anywhere > So your still saying a 400watt PSU will run i7 + 480 system , so the above facts are wrong that includes OCUK systems with a i7/i3 + 480 GPU run by a 600watt PSU and they should use a CX400watt PSU on their systems instead.
I know who l would trust to have the correct PSU in i7 + 480 GPU systems, do l need to say who or will l spell it out for you?
