Q9550 CPU voltage help on X48 MB thanks
27 May 2007
Kent
Hi all,
I have my Q9550 clocked @ 3.53ghz on a Rampage formula X48 motherboard.
But i have CPU voltage set to auto i would like to set this to a fixed amount could you help me on this ? any voltage settings to do with the CPU on this set up i need help with if poss :))
Thanks for any help.
Hey ashmanuk67 how you doing? :)
Can you say what the voltage is showing as when the processor is under Prime95 load please? . . . as seen in CPU-z
Whatever it says then manually set that in BIOS . . . . do some stability testing then nudge it down . . . . do some more stability testing then nudge it down again . . . keep going until the PC crashes then nudge the vCore back up a touch! . . .
It's a very simple process but could take a day or two so be patient! :cool:
As above, but you may have to tinker with other voltages as well, such as NB, VTT and PLL, the 45nm quads need more tweaking of theese compared to the older 65nm parts.
;)[/QUOTE]
Well easy when you know how :D so by default your MB overvolts it ? what is the main benefit of doing this ?
Thanks Big.Wayne ;)
Ok Thanks Setter, i don't think you see these in CPUz ? do you or do you using Prime95 ?
You might think it's crazy.. but from what I read a while ago about the board and quads (Q9450/Q9550) undervolting the North Bridge actually helps a lot. Crazy logic I know...
Asus are complete **** when it comes to support for these high-spec boards. They won't create a decent BIOS for it unfortunatley, although you should be able to get to 4Ghz on it :-) I'll try and find the link if I get time :-)
There does also appear to be an "FSB hole" with the boards. This means an frequency zone where it simply won't work, and you need to go beyond this for it to work.
Ah, here is one of the links, with some of the guys still pressing the boards :-) This thread is one of the most useful resources for this board and your chip out there.
http://www.xtremesystems.org/forums/showthread.php?p=4667754
You'll notice that people with other make boards (Gigabyte for example), are easily getting significantly better clocks, with relatively little fuss. These boards can be difficult :-( (Not good for a premium board).
Oh and for the love of your chip/board, turn OFF LLC (Load Line Calibration). It's meant to help with voltage droop, but just end's up massively spiking with voltage (tested and proved).
The motherboard checks the processors [VID] when the chip is installed and sets the vCore according to this info . . . the [VID] is programmed into the chip by Intel® . . .
If you download CoreTemp you can check what [VID] your processor has . . . the voltage you see in CPU-z will almost always be less than what the [VID] says it should be . . .
If your [VID] says 1.3500v then you will most likely see approx 1.3000v in CPU-z . . . the difference between the [VID] and the actual vCore you get is known as vDrop . . . its quite common but causes a few rOOkies some confusion as they expect top see the same voltage that is set in BIOS appear in CPU-z . . . to further confuses matter once the chip and associated power circuitry is placed under heavy load the vCore can drop even further . . . so if the [VID] says 1.3500v and you see 1.3000v in CPU-z with the PC not under heavy load you may well then see this voltage figure drop to 1.2750v or lower once the heavy load begins . . . this is known as vDroop . . .
Depending on the quality of ones motherboard and PSU the effects of both vDrop and vDroop have a negligible effect on proceedings and the PC 99.9% will run perfectly stable . . . however once you start overclocking and running the chip out-of-spec then you can run into stability problems if the vCore drops below a certain point whilst under heavy load . . .
Anyways regarding the [VID] and the board overvolting the chips . . . I believe Intel® play it safe and build in a margin of error by adding a bit too much voltage instead of a bit too little voltage . . in the case of the former the chip will always run stably albeit sucking up a little too much juice . . . in the case of the latter the chip will run a bit cooler and not use as much voltage but under extreme load could become unstable . . . of course Intel® don't want a user to have any stability issues with their products as it would "damage" their brand reputation! :D
So all the above is mainly background info but in the o.p you asked this question:
If you follow the instructions you have been given you will be able to determine the "exact" voltage your processor needs at any given frequency . . . all you need to do is change the vCore from [Auto] to what it says in the [VID] info and then carefully start testing and lowering the vCore until you run into stability issues . . . I always begin this voltage testing with the processor at stock myself and then work upwards . . . this is known as Voltage-Scaling-Testing and gives you a map of what vCore your processor needs at various frequencies and helps determine what is the processors "Sweet-Spot" . . . i.e the optimum balance of voltage vs frequencies . . . you tend to find that after a certain point the chip starts to need a huge boost to its voltage to gain a few meagre MHz which means you have past the optimum spot . . .
Regarding other voltages . . . as long as you stay at 400MHz-FSB or under there is no real need to play with any of the other voltage settings . . . its only really vCore that needs playing with . . . however once you venture past 400MHz-FSB you are entering No-Man-Lands outside of official Intel® specifications so as setter mantioned you will most likely need to "tinker" with other voltages if you run into any stability issues! . . .
Hope this post helps you (and any other LGA775 rOOkie Clockers reading) and good luck with your mission . . . have a nice xmas! :cool:
