Cheers, think I will.![]()
No biggy your still running S775
Might aswell match OLD with the OLD![]()
As a 5850 owner I can see both points of view, easyrider has a point but for £125 you cannot go wrong with 5850, or a 68xx for that matter. Most 5850's (including mine) will easily do 1000core and have a full feature set just like the 68 series. Sure the temptation is there to go for a 68 series because they are newer and supported for longer but then there is that mediocre trade off in performance.
Answer.... pull paper from a hat, both offer good value and near on the same feature set and performance.
Better scaling on xfire yes, but due to the card itself being slower, it is only on par with 5850 xfire according to reviews.Except the 6850 is far better in an xfire configuration
At the corners (tessellation), the 6850 is able to compete head to head with the 5850 in terms of overall speed, but once out of the corners in the the straight (dx9 or low/no tesselation games), the 5850 pulls ahead of the 6850. It is this simple.
Nope. dx11 games are like the corners I mention, which the 5850 doesn't really fall behind the 6850. Heaven Bench and Metro2033 results already clearly illustrated that 6850 is barely any faster than 5850 under those condition.So what you are saying is the 5850 is faster on current race tracks?
What about Race tracks yet to be designed... DX11 Racetracks? Racetracks of the future.
I get it very well thanks.
Who cares about DX9 games anymore DX 11 is where its at
My old 4850 destroyed Doom 3...See what I mean
I'm gonna chuck my HD5870 in the bin, it's clearly redundant as well...
FML!This is one hell of a thread. Location says it all. In Denial
The load power consumption of the HD6850 1GB is lower than an HD5850 1GB and it only requires a single PCI-E power connector too. Most HD6850 1GB cards tend to be shorter than the HD5850 1GB so it means that an HD6850 1GB can be run in more systems than an HD5850 1GB.
Oh Dear
Not that one again used so many time by people who think they are being witty
Fact is I make a valid point.
Power consumption might be lower but maybe, just maybe it could be partially due to it being a less powerful card... I'd rather have my 20% better performance at a lower cost than get a 6850.
