Coolermaster HAF 912 PLUS Fans
14 Jun 2010
Can anyone Spec some Fans for my Blackops pc please? I have Coolermaster HAF 912 PLUS case need:
Top Cooling: 1x 200 mm or 2 x 120mm fans
Front Cooling: 1x 200 mm or 2 x 120mm fans << if you think be better than the stock fans.
Thank you.
according to the coolermaster webby it is indeed 105cfm @ 19DBA
not sure about how static pressure works from what im told its not that great so perhaps that means its actually a bit less than 105cmf? i dont know i just know i couldnt find any better 200mm fans.
Static pressure, at least where it's related to fans is to do with their ability to push air through a restriction, whether it be a grille, filter, heatsink or even against a stream of air. A high cfm fan with low static pressure will fail in any restrictive application against a lower cfm fan with high static pressure.
It normally doesn't matter too much for case fans unless you have a restrictive grille and filter to push or pull through.
