My comment about higher current handling was more aimed at people wanting to overclock.The problem with saying that thicker copper handles higher current's better is that current produces heat and heat causes resistance which actually reduces, not increases, the current's abilty to flow.
More copper on the PCB actually makes soldering more difficult. This is because the thicker traces act like a heatsink and it's hard to get the area you want to solder up to the temperature you need in order for the solder to melt. I would say that thicker copper would improve reliability though, as usually the PCB itself is thicker and stronger also...I wonder if the added copper in the PCB helps reduces cracked solder joints. If the mobo has more copper, it might expand and contract with the solder when things heat up, and increase the reliability of the boards. It might also make the boards stronger, and more able to withstand the flexing caused by heavy heatsinks and graphics cards.
That hurt my head. Wouldn't thicker copper be more efficient in carrying the said current, thus produce less heat/resistance?
Yes. The easiest analogy is thinking of water going through a pipe - the smaller the pipe, the harder you have to force it through.
