Hi
I would very much appreciate your advice on my situation (and apologies for the long post!):
I currently have a:
Processor * Intel Core 2 Quad Q9400 Quad Core Processor 2.66Ghz, 6MB Cache
Motherboard * XFX 750i SLI Motherboard
Memory * 4GB Expandable to 8GB
Hard Drive * 1TB (1xTB) SATA300 Hard Drive
Optical Drive * 20 x Super multi DVDRW
Operating System: Microsoft Windows Vista Home Premium
Graphics * 2 x nVIDIA GeForce GTS250 512MB DDR3 Graphics Cards
with a monitor running 1920x1200
Which has worked fine for maybe 2 years but occasionally it started freezing up playing games. Now I recently started getting 3-4 beeps on POST. Then the PC stopped booting at all and Vista couldn't successfully repair itself - 'Bad Driver...'. So I got a new HD (OCX Vertex 2 120Gb
)and a copy of Win 7 upgrade.
After installing the new HD and putting Win 7 on it I still get 3-4 beeps on POST. According to AMI codes this means probably RAM or maybe motherboard. I have swapped the RAM sticks around individually in all 4 slots and all ways get 3-4 beeps. I ran memtest86 and it was still passing after 4 times. However Prime95 goes 1-5 mins before getting BSOD. And it's crashing now using normal apps so it's about to die.
So I'm unsure if the solution is to replace RAM, or if it's actually the motherboard or I read it could be PSU too. Question 1: Does anyone know ways to tell for certain which it of these it might/might not be before I start getting replacement bits?
e.g. I can't see a socket 775 ddr2 SLI in the motherboards list here but maybe I'm blind
Q2: If there is one still made, what MB/PSU/RAM should I get?
Failing that, do I have bits worth rebuilding round? I haven't built my own rig in years so would I be best to go pre-built with the current best vfm cpu/graphics card and bin this old one?
Thanks for your thoughts!
I currently have a:
)and a copy of Win 7 upgrade.After installing the new HD and putting Win 7 on it I still get 3-4 beeps on POST. According to AMI codes this means probably RAM or maybe motherboard. I have swapped the RAM sticks around individually in all 4 slots and all ways get 3-4 beeps. I ran memtest86 and it was still passing after 4 times. However Prime95 goes 1-5 mins before getting BSOD. And it's crashing now using normal apps so it's about to die.
Q2: If there is one still made, what MB/PSU/RAM should I get?Failing that, do I have bits worth rebuilding round? I haven't built my own rig in years so would I be best to go pre-built with the current best vfm cpu/graphics card and bin this old one?
