just showing off my case ;)
4 Jun 2010
thought there was to many pic's to post in "show us the inside of your case" thread so i made a new thread :) here it is (spec's in sig) second build by the way.
im gonna go braid crazy at Christmas (might watercool as well :D) and also get a side window with some cathode's i have caught the upgrading bug :( but the 700d was a result of the upgrading bug so it cant be that bad can it?
Are you sure? It looks like from the pics that you have the yellow viper fan around the wrong way. Push/Push.
from what i can feel there is a large amount of air being pushed towards the rear outtake, and the other fan is pushing into the heatsink, either way it keeps my keeps in the 20's on idle so im not too worried :D
Fair enough I suppose. Must create a big bunch of turbulence though as the air from one fan meets the other in the centre of your heatsink, it must throw all the heat back into your case rather than out the back as desired. I suppose it cools your motherboard as a by product and the air is probably promptly sucked out by those imposing looking fans in your case roof.
Try disconnecting the left side fan and see what difference it makes though, just for curiosity's sake. I wonder if it makes a temperature and noise difference.
