***The Official Gran Turismo 5 Thread***
1 almost perfect lap then second is poo :(
Are you meant to catch up with the Seb Vett ghost or match it?
All you need is to get a bronze on all 3. Although if its anything like the Loeb challenge you'll get a trophy if you cross the line in front of him. Which is probably impossible. I'm gunna wait till I get one for B-spec Level 35 then practice a whole load with it and try again, then I'll have two :D
OMG PEOPLE! I finally have it in my hands tommorow yahoooo :D So if any one else got the SE edition did the extra cars go straight to your garage or do they just unlock for you to buy?
The seasonal events have been a mixed bag for me so far.
I managed to do a good few of them with just sports suspension and a short 6 speed gear box and some weight reduction.
Did the skyline one for instance through repetition, trial and error. Won the Mini Cooper challenge after a few tries. Won the first RX-7 FC not too difficult.
However, the Fiat 500 and the Focus challenge i was ~ 10-15 seconds off first place so i had to go for Skid Recovery, which which i improved by 2-3 secs a lap and rinsed the events.
The new RX7 one is in limbo for me now. I can do 1:02-1:03 but i believe you need to be doing 1:00's to win. And i cant get 1 lap that fast, let alone 10 in a row, so maybe ill need to resort to skid recovery here:/
I demand that you provide your setup and mods for, at the very least, the fiat 500. I put the aero mods on mine, maybe not wise. sports filter, but then I changed the oil and now even without the sports filter it's over max power. Are you like, level 30 or something? I hear at 30 your fully customisable gear ratios are actually fully customisable?
Umm sports filter, suspension, gears, clutch/flywheel. Didn't put aero on. TC / ASC off and ABS 1. Quite important to turn the aids off with low/med cars, else you just get held back a lot.
I'm not sure of this problem people get with the oil, I bought the car new so didn't need it - just added the sports filter.
I'm level 23.
Bennah Skid Recovery?
yes its in driving options just before u click race. it makes your car grip when it would otherwise have spun or something. Makes u much faster and stops under/oversteer allowing u to go much faster around corners.
I'm level 23.
Even when u buy a new 0 mile car u can change the oil and it usually adds between 1-3% extra HP.
Some of the car events if u buy new car and add oil, it puts u over the max allowed for that event.
which is retarded.
I may have forgotten the clutch/flywheel :o
But I cba now, I've got a mini and a 500 with about 2hp too much.. so I either buy them again, which I really don't want to on principle, or thrash them till they're funked, which I really cba.
But the oil looks fine when new? So probably why I've never done it on a new car. Just don't do the oil change tbh!
its not about what the oil like. Im telling you change the oil on a new car and get an increase in BHP whether you like it or not.
However, i also tested this with a Nissan GTR R35 Spec V and it didnt matter that i ran the event first and then changed oil afterwards i still got exactly the same increase:)
Yes now know that. It's pretty retarded tho isn't it? You put fresh oil in, oh, you can't do the race now. #!:>?|>!!?!??? :mad:
Bennah, earliest I could send you a Gallardo would be day after tomorrow, sorry.
Seriously, if this forum has a PM system, which I have yet to find, send me one then if you still haven't got one.
yes, it's in the GT5 news, hence anyone who's been on the game knows. Bit late, it being xmas eve and all!
I am to poor for that anyway. *struggles with a pad*
it appears the easiest way to win these seasonal events is to buy the fully customizable suspension / LSD, Drivetrain and make sure you know what you're doing with it for the type of car.. not very easy for those who havent played gran turismo for a long time (like me) but once i got back into it it makes a huge difference, especially if youre driving a heavy car
edit: thanks bennah...
edit2: could you loan me it for 30 mins? I cant find one on the market right now, game name DeLiTa7x
Will do fella. Just in the middle of a championship atm. Give me half hour.
Don't suppose you have a Gallardo do you?
I havent played GT since GT2 so its not that difficult - you just have to be very accurate with your driving style and most of all be consistent. Try and pass cars at the best possible times and attempt slipstreaming at all times possible (especially down the long pit/back straights). So in that respect its just like every other GT - learn the circuits, understand how your car behaves under braking, cornering and acceleration and marry the two with your car setup...
I would recommend all the drivetrain changes (flywheel, clutch and rod) and fully customised gearbox - I dont think suspension is that important, that matters on the specific track and your driving style - if you find your car has large amount of body roll (RX-7 is a good example) then stiffening bars are much more useful to reduce the lateral g force which is preventing you maintaining corner speed.
One thing I noticed on the GT-R challenge is that 4WD just understeer badly, previously Ive been able to introduce slight oversteer by changing brake bias to the rears (just means your fronts dont lock up as much due to reduce braking requirement and so hopefully point the car more into the corner). With the GT-R this wasnt enough so I did opt for the torque modify mod - putting that on even at default settings (30/70) makes a 4WD car much more pointy like a RWD (how I prefer my cars to behave) and so allows better corner speed, just watch how you apply the throttle...
The seasonal events have saved GT5 for me - the rewards provided reflect the effort in maintaining a good driving style and 'perfect laps' and allows you to pick up good habits for other events.
I would say SeVen that you might be better equipped to do some grinding or some time on practise and get your head around those setups, just that time unlocking how a car feels and what you can do to change it to your preference will help you more than just borrowing cars and not getting how others can do it but you cant...
EDIT: Also dont forget vaguely attempting to keep your car in the rev power band if possible - means you accelerate far faster out of corner - but thats not always possile on AT (yes I sadly still use AT)...
ps3ud0 :cool:
