XBMC Setup for TV Shows
15 Sep 2009
Birmingham
I've just set my PC up with XBMC and the films are all working fine with descriptions and posters etc. But I can't get the TV shows working, they are currently set up as;
E:\TV Shows\Show Name\Series #\names S00E01.file extension
But when i go into the tv shows in XMBC I just get the list of shows with the file name I've used. No artwork or anything, can anyone help?
As long as the file has a Season and Episode number in the S??E?? format it should pick them up.
Make sure you set the scraper to use the folder name for the Show Name and check thetvdb.com to match.
When I use EMM it picks up all the information and episode names etc, but when I go into XMBC I get the pictures but no descriptions. I just get BlackAdder.S01.E02 for example and a screenshot from the episode.
Any ideas how I get all the descriptions in?
try disconnecting from the internet when u go to update libary in XBMC. Its annoying but it works for me
