Bad Company 2, BT Router issues?
14 Jun 2010
Hi
I purchased BFBC2 about 1 week ago I have been having problems playing online, during the day I can connect and play find but some times 30-40% of the time the game Disconnects but I m still connected to the internet.
If the evening its near imposable to get on any server between 7-12 ish, I have done some research i've open the ports on my router checked my firewall etc, found few posts of people blaming BT Broadband or the Homebub 2 router?
Does anyone here have BC and BT router have the same problems?
Edit-I have Homehub2 Router
Merry X-mas
Don't know if this is any help but im with O2 and had problems disconnecting every 20 minutes. It was a problem with the router and NAT isssues.
Bought a Netgear DGND3300 and it's been perfect since.
Just saying it could be the router, although im sure a lot of people on BT dont have that problem so it could hopefuly be sorted in the router settings.
Good luck :)
Good luck :)
Any Chance you are playing BC2 on pc? does it run fine between 7pm to 11? only time i can't get online with this game starting to think problems with BC2 or BT capping the internet speeds
Im currently using a BT Home hub with upnp enabled and I dont have any problem with BC2
Though I have set up port forwarding for my pc network connection.
What ports do you have open? are they the same as the link i posted above? I can finally connect now lol seems to be between 8pm and 20.30 i have connections problems
These are what I have set
I have home hub 2, same problems kind of, upnp when on does loose connection to game for sure, have it on for my lads xbox and if i forget and then go play a game i will get a disconnect, go to router and switch off upnp and it works fine, between 7-11pm it is allmost impossible for me to play due to the bad service bt provide, i have had trouble since moving into an area that has no LLU at the exchange, bt wholesale only so I am kinda stuffed, what exchange are you on?
Thank god its not just me then lol been trying to fix this issue for the past week, not sure what you mean by exchange but is this what u were looking for? SDPLBRG ?
the telephone exchange you are connected to, do you know which one, just to see what broadband options you got there, i only have bt wholesale available to me and its pants.
edit, yeah looks like you get a bad service like me, it's just the way BT are i think
take a look here
http://www.samknows.com/broadband/exchange/SDPLBRG
theres no love for small villages from broadband providers.
take a look here
Lol sucks though the internet was worse here than back at uni house, guess that's what you for livening in a village
I get all sorts if issues with my homo hub and it's been going on for two years now , lots of broken BT promises.
Will be switching to sky in March so will have to make do until then .
BT home hub is a joke. I just got back from staying with my mum for a week who has bt home hub and port forwarding just would not work.
