- 18 Mar 2008
Here is the question
for A) it's easy. Just use the cosine rule
For part B) I drew a triangle LST and worked out the size of angle T. For the sake of simplicity, let's say it's 52'. But then how do you work out the bearing of S from T??? The markscheme for the paper says
285 + angle T
where does the 285 come from?
The radians bit is easy, it's 2 radians.
Then, the overall angle is 114.6'
But then the markscheme just says that the bearing can be anywhere between 293' and 294'
285 + angle T
