Hi all,
Woke up this morning to the sound of rushing water to find an outside pipe had burst. the pipe only fed a cold tap outside and had previously gone above a turn off joint, which I just turned off as it is never used in the winter.
However this time the pipe has actually split, about 1cm long facing the wall, and below the stop for it which means I've had to use the main one in the house to turn it off. We now have no cold water to the entire house or the boiler.
Are there any quick fixes I can do to bodge it until I can look at replacing it later in the week?
Also, anyone any links to sites that cover the basics of plumbing? so I can have a go at replacing it myself. I am then going to build a wood cover the entire pipe and fill it full of newspaper to try and insulate it better!
