Always check your shutter speed, 1/60 is generally the minimum for hand held BUT you also have to take into account the focal length of your lens and multiply it by your crop factor. For example 200mm lens on a Canon crop; 200 x 1.6 = 320, so 1/320 should be your minimum shutter speed. These are only guidelines, you may still get soft shots due to camera movement so just increase your shutter speed.
Crop factor doesn't apply. 200mm is 200mm regardless of your sensor size.
Apart from the field of view isn't the same, which IS due to the crop factor. It has a very evident effect which is easily seen. The shutter speeds I quoted are only guidelines, good technique / steady hands will obviously enable slower speeds to be used. Time and time again you see posts where people are unhappy with results due to soft images where too slow a shutter speed has been used.
But your point wasn't related to field of view and your post was unnecessarily confusing to a beginner. It was also incorrect.
Don't patronise those with less experience. It's a steep learning curve when we start and is only hindered by being given excuses for failure.
I'm with Rojin on this one - the crop factor does apply and should be taken into account.Crop factor doesn't apply. 200mm is 200mm regardless of your sensor size.
Shooting RAW already? I'm not sure if that's brave or stupid, but good luck either way.Well I did get said camera and was given the 18-55mm f3.5-5.6 IS lens with it (slightly better than the one you get as a kit I'm told). Quickly filled the 4GB card it came with, shooting RAW. Ordered a 16GB card too. Ill post some of the pics up when I've seen them on a proper monitor rather than a laptop and maybe had a fiddle in photoshop.
It won't be as good as a load of other lenses that you could buy, but it's easily the best lens you own and more than adequate for the job in hand.Ill be going to a Digital Art festival in the new year doing a lot of indoor photography so I was thinking of investing in a wide(r) angle lens but would my 18-55mm lens actually be ok for this sort of thing?
Forget about buying anything new for now. Concentrate on learning to use what you've got and how to get the absolute best from it.
So far I'm selective enough about what I'm photographing I've actually had enough space to store RAW pictures. I guess when I'm using the 16GB card I might get a bit more shutter happy. Size is the only downside as far as I can tell? I'm fairly Photoshop literate as a result of the Uni course I'm on so any necessary changes before compression shouldn't be beyond me.
As the highly-knowledgable chap who replied to your post first has already pointed out, processing time is the major downside of shooting RAW and it's a slightly different ballgame to working in Photoshop itself.Size is the only downside as far as I can tell? I'm fairly Photoshop literate as a result of the Uni course I'm on so any necessary changes before compression shouldn't be beyond me.
The reason I'm slightly hesitant to recommend shooting in RAW to someone who has just bought their first SLR is that it's not strictly necessary at first. There's plenty to be getting on with before you start worrying about having to edit every single image that comes your way, not least understanding exposure and composition.I still recommend you shoot raw because, well, what's the point in having a DSLR if you're not taking the time to process your images properly? But some people disagree I guess and if you don't want to put that time in then you're better off in jpeg mode.
