- 7 Feb 2004
I contacted BT and they said that the line was fine when checked. They say I can have an engineer out but if the fault is within the house or no fault then I will be charged £127
What can I do to check it or is there something I can try to fix it myself?
I lost the internet initially but I have got that back with a wired phone. But it is half the speed. Was 8mb now it's only 3mb. Would that be caused by a bad line?
I have plugged the line directly into the mastersocket internal line but am still getting crackling.
I disconnected the adsl filter and plugged the phone in directly but still get the crackling so I don't think it's the internet.
Any suggestions before I have to call out the engineer and get ripped off by their charge?
Thanks
Thanks
