Do you put your chocolate in the fridge?
Cold chocolate tends to take longer to melt in the mouth, so yeah I do enjoy it sometimes. But I don't actually put it in the fridge.
Don't put it in the fridge, else this might happen...
Frozen Galaxy is might hard!
I only put it in the fridge if it's overly warm, but then take it out and let it come back to room temperature before stuffing it down my neck.
Cold chocolate, while 'crisp' doesn't taste as nice.
Ideally it should go in the frige, come out, get sliced really thin, and then be allowed to go to room temperature or maybe even a little higher - at least to my preference anyway.
Brush your teeth more often and you'd be ok. Nothing to do with the chocolate, more to do with personal hygiene.
Indeed you're correct, I had decay on that tooth so it was only a matter of time, the cold chocolate just accelarated the process :p Brushing more wouldn't really have helped btw, it's all about flossing (which I didn't do at the time), I was 22 when I did that and had never had a filling so it was a bit of a shock!
YES cold chocolate is far nicer than warm chocolate....unless it's a galaxy ripple in which case it's tasty in any form
