thats more down to the needs of buyers.
As i've already said, off the shelf maps arent popular with the community and few can resist the temptation to go further and get more power.
so a base ECUTek remap gets 250bhp ?
but an open source based map can get 270bhp + ?
are there any other costs ?
I didn't say there were power difference. They both get the results just in different ways. I was simply saying that you would be a bit silly to spend £600 on a ECUtek map on a standard car.
any idea why ?
Is it because it can't be done or just because there isnt any demand ?
)There isn't an off the shelf map (that I know of) for the impreza in standard form anyway.
It's PPP or nothing (which includes a sports cat downpipe at the very least)
I'm confused if there is no power differences, what power levels do they produce
because anything from 250 to 280 bhp has been quoted so far ?
depends on ability of tuner, depends on braveness of the tuner to a large degree also. depends on boost level, condition of the engine, fuel used, type of dyno.
This is where all the discrepancies start creeping in
Tell you what chaps, easy way to settle this, we all chip in for remap on my stock (bar a prodrive backbox, can't make any power difference??) 2.0 WRX and get before and after graphs done.
Then we'll see what a stock car makes after a remap.
A few pounds from many members and this can all be settled
(well it was worth a try)
PPP pack for WRX does not include sports cat downpipe. The downpipe was only included on the STi PPP, all the WRX got was the intercooler Y pipe, new centre section with the silencer thingy removed (not an actual cat as people believe), backbox and a remap.
Very true, as sacriligious as it might sound if I got mine done I'd want a safe map that could be very safely run in 95ron without risk of going boooom.
Never seen a PPP on a wrx with a std downpipe in 5 years I've been there.
Have heard this being mentioned before though
Which would mean you need to map it on 95ron then.
any idea why ?
