Spec check for new build please
1 Feb 2006
This will be for my brother who mostly uses photoshop, general usage, and very light gaming.
How does this look? Is there anything that I should change? Is the 5770 ok for light gaming on BFBC2 and Dirt? I was trying to talk him into an SSD for PS work but I don't think he would get enough good from it. 2 x 1 TB drives should be fine with further backups going on a NAS.
Thanks
That setup would rip through dirt 2 no problem.
If you had an extra £20 you could get a GTX460 which would allow much better gaming performance overall.
BFBC2 does prefer quad core CPU's. But i guess it all depends on the res being used.
@ 4Ghz I doubt the i3 would cause too much of an issue.
Good solid PSU.
Case is a personal preference but if ££ is an issue their are some cheaper nice cases about. The CM Advanced Dominator II is a popular choice. Or even the CM Elite 430.
What is his overal budget?
I think around £600 would be ideal. Wasn't sure about the 460 v 5770. Would there be much in it for £20 worth?
I have the Fractal case and it fits the dimensions nicely - the CM Advanced was too big.
I think the i3 would be nice and cheap for him - i5 probably takes it above budget too much.
The 768MB Version is still much better.
The Gigabyte and MSI cards are your best bet.
Your looking at around 3-5fps better in the 1Gb version. Not really worth the £35 extra IMO if its only for light gaming.
