- 29 Aug 2010
- Cornwall
I currently have a Corsair TX750 powering:
Phenom II X6 1055T @ 3.8GHz
Gigabyte GA-800GM-UD2H
4GB Corsair XMS3
2GB 4870x2 @ 800/1000
1TB Samsung F3
LiteOn DVD drive
XSPC X20 750 res/pump combo
and 8 fans
I settled on the TX750 after using the PSU picker on the Corsair site. Depending on my overclock setting for the CPU/GPU it suggested either 650/750W or 750/850W PSU.
Now I've decided that as I'm a bit rubbish at cable tidying a modular PSU would be handy. Also, as I'd like to fit a 240mm radiator in the bottom of my case I'd prefer a shorter PSU to give me as much room as possible.
So I'm basically trying to decided between the Corsair HX650 and the CoolerMaster Silent Pro 700.
Would both/either of these PSUs be OK for my system?
Also, in the future I'm thinking of replacing the 4870x2 with a 5870. I imagine this will reduce the power draw of the system? If those PSUs aren't good enough for the system as is, will they be if I switch the cards?
Lastly, any other PSUs for the same sort of money that would be better?
Thank you kindly for any help and advice.
4GB Corsair XMS3
1TB Samsung F3
LiteOn DVD drive
and 8 fans
