Plan to upgrade to a 7200rpm drive as soon as I get paid, just wondering if anyone else has something they recommend I try before buying?
EDIT: I forgot to add, found something pretty strange as a temporary solution. If I have an anti-virus scan running in the background, I do not get these stutters half as often, I have no idea why it does this, also tested with running defrag in the background and that helps to an extent also. No idea why this would be the case.
BTW guys there's a BIOS update out for the 660 now, doesn't look like it does anything major though.
I flashed the new BIOS when it was released and it hasn't changed anything. It's only made the cold BOOT issue I have even worse.
The antivirus / defrag will keep the drives active and hence stop them from parking / unparking.
As for drives, go with a WD Black or a Seagate Momentus. I went for the Seagate but to be honest I wish I'd have gone with the WD, as the Seagates can be a little 'ticky' from time to time.
Laptop is raided to 0. To see your 2 hard drives or newly added. You need to set it to Normal. Go to your BIOS settings, you will see![]()
I caved and ordered an SSD today. Went with an 128GB C300.
Ok, my first official whinge. The lappy won't detect my SSD in AHCI mode, only in IDE mode.
