12V Laing DDC-1T+ Ultra 18W (MCP355)
12 Apr 2009
Hi guys, so I was cleaning out the system and put everything back together with everything in perfect working order. I left it on overnight to see if there's any leaks etc before I hook it up to all the components (mobo, cpu, etc.) just to be on the safe side, as is procedure. Anyway, I check in the morning, and the water from the reservoir has gone considerably low, a little water on the floor, and the pump isn't working no more! The water leaked due to a loose fitting, but I tried and I tried to fix the pump but to no avail, it's 'knackered'! The only explanation I have for this is that the water from the reservoir totally leaked out and so the pump ran dry for a bit and just broke, and some water from the radiator above dripped into the reservoir, which is why there was still a little water in there in the morning...
I connected the 3 and 4 pin connections on the pump to the many connections from the PSU but nothing. Everything else on the system is working, I should mention that the display on the fan controller was a little distorted but when I reconnected wirings it's running fine now. Just found that a little weird :confused:
I'm trying to now look around for a pump (12V Laing DDC-1T+ Ultra 18W (MCP355)). But I just need the PUMP, everywhere I look they are selling the reservoir with it too. Anyone know where I can just get the pump ONLY or even any how I can check to permanently rule the demise of my pump??
Nobody is going to be able to tell you I'm afraid as any company would be a competitor. But yeah, you can't run the DDC pumps dry for any length of time.
ok I have some developments:
Took the pump out completely off it's housing too. Connected it up and the rotor spins for a milli-second. However, when I push the rotors myself the pump works fine! It's only when I push the rotors though that it works.
Does shaking it have the same effect?
Maybe needs a good run with water
No shaking doesn't do nothing I'm afraid. I am suspecting the circuit board on the bottom of the pump. I gave it a dry and ran a hairdryer over the whole thing. Now it seems to want to work a little, it's worked by itself twice now. How shall I give it a run with water? Just thinking I should submerge the pump into the water (and obviously keep the circuit board out)
No no no
Rebuild it.
Attach hose to it and have it pull water from a bucket and dump back into bucket
If it keeps running for more then 5 hours then its fine.
Personally I would put it in a bowl of rice for 2 days when in bits
No no no
Rebuild it.
It just doesn't work when I fill it up with water.
Excuse the ignorance, but what purpose is the bowl of rice technique for?
The rice will dry things out.
Is there fluid inside the pump were the circuit sits. If there is then its U/S.
