Is it the true end of a decade tonight or was it last year
Well when you say like, the ninetys (90's), that began in 1990 so following that example, we already started this decade! ;)
The end of the decade is tonight - the same as the end of the last millennium was at the end of 2000 - not the end of 1999. Unfortunately the general public are too ignorant to understand this concept and so we always celebrate the year that Joe Public thinks is correct.
I want to be you.
:confused:
Unless you're going to bring up that whole 'the first decade started on year 1 because there is no year 0 therefore 10 was still part of the first decade' thing, which is just nonsense semantics.
I can hardly believe we've gone through 10 years of the new millennium already. :(
Where does it all go :(
Complicated question. Actually tonight we change decade, pretty much the same way we actually changed millennium in 2001 and not in 2000.
The reason is very simple. When we moved on to the new calendar we started counting years from 1. There was never year 0. So if you start counting from 1 then you complete 10 digits if you include 10 itself. So a decade as you guessed it spans from 1 to 10.
Things get complicated when you consider the consequences. Astronomers for example, actually use year 0 to compensate for this so their numbering system for years is not the same as the Gregorian calendar. The problem is not simple semantics unfortunately and it cocks things up for many scientists who have to consider absolute time.
So by the calendar we currently use, the decade is changing tonight. In terms of absolute years it changed in 09. So basically the average Joe is actually celebrating in terms of absolute years while thinking that he is celebrating in terms of Gregorian calendar. :p
:confused:
it is a very valid argument actually and not semantics at all. read post above for explanation.
