Connecting Tubing Together
Dcc
Dcc
8 Jan 2009
I am upgrading my 9800GX2 (watercooled) to a GTX 570. Since I'm moving back onto air cooling I'm going to need to remove what was the old gpu waterblock from the loop.
So as to save me a bit of bother (and instead of having to fit more tubing if at some point decide to cool the 570) it would be great if I could just fix together the two pieces of tubing that I would need to cut. Are there any such fittings out there that would do this? Like a T-line without the extra connection. I have found one male to male compression fitting on the net that was the wrong size but not much else. I was thinking maybe it would be easier to buy a T line and block the third junction off, or is that just daft?
Any help is much appreciated,
Dc.
