OcUK - Where is your stock of Cases?
26 Mar 2007
Nottinghamshire
[Cas];18114148 said:
They must not like you, because I've always had a quick reply in there.
Maybe, i've made 3 or 4 threads, 2 didn't get answered and the others took quite a while.
To make you guys aware, 90% of all UK suppliers are closed until early Jan so the fact we are open is a miracle. So you will see products go out of stock during this period as we cannot re-stock them until suppliers re-open. I hope you all can understand this.
OP - If it helps I've very recently gone through all the black mid towers to find the right one for me. I settled on the Fractal Design R3 and frankly I'm delighted with my choice. OcUK got a delivery in just before Christmas, but the shop only shows 5 left.
Here's the Bit-Tech review of it, which is particularly useful as it has a comparison table for similar cases.
Cheers Nath good enough for me buddy.
I'll hold off for a couple of weeks.
Front door = no go for me.
Thanks for the suggestion though fella.
