Hi,
I had a problem with the retail disk, I had Samsung DVD-RW and for some reason the disk did not like that drive at all and would not load. It checked the disk and span up etc etc, sounds similar to your issue. Heck I even downloaded new firmware for the optical drive, still no result.
I have a solution, you may not like it but it worked for me.
Download the EA downloader prgram and use the code you had with the retail disk to use the digital edition. You will then have to download the game again and therefore eliminate the need for disk checking. It will just check for patches then only.
The digital edition works perfectly for me, and looks great. Your 5700 should be able to run it no problem.
I hope this solution can help.
Note the retail code does not work with Steam...
Cheers
Von
