Some hefty challenges for a £600 laptop
maybe looking at 4/6gb RAM, and maybe an i3? and some sort of dedicated gpu ofcourse ,for rendering that is, especially with 3Ds Max
will have a browse tomorrow morning, quite tired atm just came on for a browse, will update tomorrow
was this Dell laptop good enough for rendering on the jobs this new laptop will be doing, as the spec will come in handy when browsing
I know it's a challenge, that's why I asked on here as I know these boards have some knowledgeable people reading these threads
, so many thanks for your help/advice.
Spec of the Dell is...
c2d T5750 @ 2.0 GHz stepping D, Revision M0
3GB ram pc2-5300
Integrated graphics 965 chipset
250 gb hdd.
It was kind of ok'ish on rendering smaller files, but with the big stuff that she now has to do (final uni year), it started to struggle but did the job eventually.
Definitely a minimum 4gb ram, and m'be one that can take 8gb
i3 or i5?
Would a dedicated GC be better than integrated graphics?
250+ hdd.
The Dell was fine till the start of Dec, she was rendering when the laptop just closed down. She thought it could be heat problems so she let it cool down then carried on. During Dec the laptop has just closed down without reason, this is while she was working and also when she was just watching a dvd. It closed down yesterday while she was listening to an audio book and browsing but didn't tell me till this afternoon.
I took the plate off the bottom, cleaned it out with a tinny of compressed air when I noticed that a screw holding the heatpipe/heatsink covering the NB? was loose. I tightened it up, ran 5 passes of IBT and all was fine, I then ran Prime and it closed down again. I then ran memtest, all was fine for 40 mins when it just closed down again. I took the heatpipe/heatsink off the CPU and NB, cleaned it all and applied AS5.
Tried running IBT/Prime but it still closed down, tried removing the ram, put one in then the other but it still closed down so now she's looking for a new'un.
