Minecraft OCuK Forum Members Server Thread
I don't know if that is an old map of minerals, but it's not accurate. Diamonds start at level 1, not 10. Iron, Coal, Gold etc start from level 1 also and there's no layer of lava above bedrock.
Pinched from the Minecraft forums.
Bedrock/Adminium is in depths 0-4 (going up increases "depth")
Diamond is normal up to depth 16 (Redstone too)
Gold is normal up to 32
Iron is normal up to 64
Coal is normal up to 128
Yeah I probably should have mentioned that! It's pretty much correct other than it's everything "up to" rather than certain ranges :)
Just reserved vault 8 for myself (Tribee) and vault 9 for my friend (Spokwiththemears) If you could protect them that would be fantastic :)
I only have one thing to add about the railway.
Railways should run on flat ground they should not go up or down more then 1 block for every 50 blocks, thats 50/1.
This means when laying the tracks if you come to any of the below this is what you do.
Hill = Cutting
Mountain = tunnel
Valley = bridge or embankment
Sea = bridge or tunnel <<< 1 block drop for every 50 blocks
Fenced & torches to make monster safe.
Your house should go to the railway not the railway to you house, so if you have built your house on a hill then you make a path down to the station.
That sounds good, what level is designated as the starting level, or 'ground zero'? Sea level?
Thats cool and i'd be up for that, but the original plan was to join up with ApeZ and the Rizo's.
How do you guys feel about a central station that links to spawn in the middle of our sea and then join it up to each of our places individually? That would be cool right?
Here's a quick mockup of where we are all located:
Let me know what your thoughts on what to build where.
if you hook up to rizo's tunnel that goes near the dwarf we can connect them to the tunnel e made that goes to spawn.
TNT no longer for sale in shop due to thefts and people sticking cobble in instead of the right payment.
Although VER I'm willing to set a chest up in your base for you to take from if you want
I'd like to be added to the whitelist if possible, i haven't got 5 posts unfortunately but i have been a forum member for 2 years and "Jimaroo" can vouch for me =].
If that's ok my user = brooky4eva
Aye, not active within the OcUK forums but can certainly trust him on our beloved Minecraft server. ;)
I would have used spawn as the starting level
Whitelist updated
Vaults updated
New map on way
Don't dig down under spawn as you will fall into a lava lake the size of the spawn town, please do not cover it over as it's there to stop mods spawning & thats whats makes the server lag.
The void will be filled with a 3rd level of vaults as I am going to have to open the 2nd level up soon.
While making the void I have destoryed someones work that was under the spawn town, but as it was said before this world was made that the vaults would be going under the spawn I dont feel bad about it.
Forgot to add tefals last post reminded me, the server shop is now on hold & may not been up & running this is due to the mod been so over the top in opitions I can't work thing out, it use to be really simply but the guys gone way ott with it.
Plus looking at how the players are getting on do we really need it ? If the prices are wrong it could easy replace dupping I have to be so carefull not to ruin this world.
You can still traid with each other by swapping goods just use your vaults for storage.
Tefal, I am in the process of making a new base at the moment but something like that would be good.
I'll give you a shout once its completed !
Thanks.
Shame on the people who are steeling.
Wow, sever is up to 24 players now right? and its still full :(
I hope it dies down a bit once everyone starts getting back to work/school (although not die down too much).
Oh no. I just disconnected as i had invisible mobs, lost all my stuff. Now can't get back in. :(
Will someone be a saint and go to my treehouse, recover said stuff and put it in my chests upstairs?
