should i overclock
3 Jan 2010
Hailsham
do you think i should risk overclocking my system, would i get noticable results from it?
here's a link to someone else trying to overclock the system,
http://forums.overclockers.co.uk/showthread.php?t=18098215
heres my spec
AMD Phenom X4 9650 Quad-Core processor (2.3GHz, 2MB Cache) Genuine Windows(R) 7 Home Premium 4GB DDR2 memory 640GB hard drive 512MB ATI Radeon HD4350 graphics DVD Rewriter Built-in wireless (802.11b/g)
FOXCONN A7VMX-K motherboard, The BIOS is American Magatrends
Overclocking your system is totally your choice.
IMO overclocking CPUs and GPUs has improved perfomance of the PCs that i have built, im no pro at O/Cing but do it for fun, just to see what my PCs can achieve.
Noticable results will come from benchmarking your system using various benchmarking software programs.
Good luck with your choice
heres my spec
You could overclock it like ReAPeR101 siad. Since its not a custom built pc and bought from a store ( Or not? ) like pc world you will have to check if the bios allows overclocking since a lot of them dont, judging from that link however it seems like the bios can be updated to allow it. Anyway, in my opinion as long as it doesnt void your warranty ( check that ) you should be able to overclock that easily, I personally wouldnt add any voltage though as I dont think the ram could take it and it hasnt got a custom cooler. But it could be worth overclocking, what do you use the pc for general?
gaming, though im building a new rig and this will be for her but she will still want it for gaming, looking at putting a new graphics card in it when i order the rest of my stuff:)
just trying to work out if i'd notice it overclocked
also have a good 550w psu to go into it
