- 24 Dec 2010
Any suggestions?
I find it really good for gaming, i play black op on the max setting and get a fps of 130+, crysis max setting of a fps of 50. For Internet browsering really fast. This all depends on what graphics card you are getting, I have the 5850 but I'm thinking of upgrading to 6950 in the next few months. All in all very good system and love it..Btw Sgt Tackleberry, you seem to have the exact same CPU and RAM I plan to get, how are you finding that setup?
If this is Pc is for the music production then I think you will need 8gb ram.
Yeah I was thinking of starting with 4GB then maybe adding another 4GB later.
I might overclock it a little, maybe in the region of 400MHz or so, is that going to make a lot of difference?
If you want to push the cpu, you'll want to be shopping around for the Noctua NH-D14 or Thermalright Silver Arrow, but be warned, they're big! If you're more limited for space, the Megahalems is a very impressive cooler.
If, however, you don't want to push the cpu much, save some cash and spend about £20 instead.
