I used the trial to get a real idea of how it works, then decided it was well worth the 8.99 a month, of less if you buy more months in a row.
I purchased a month yesterday, (only as I have a couple of one month vouchers due, one from MS, and another from my sister for xmas)
Will purchase a year once they are used up![]()
Quick question, for some reason I can't connect to the internet using a data connection (via wifi its fine). Im on an Omnia7 (unlocked) with O2, and regardless of whether my connection is HSDPA or 3G, I cannot connect. Was fine on my iPhone - any ideas?
from the menu: settings/system/mobile network
click on the box 'edit apn' and make sure the APN (it's the portal url, my omnia is on Vodafone so it's pp.vodafone.co.uk, dunno what O2's url is) is correct and also the username/pw's in the appropriate boxes are o.k.
MS only promised Copy/Paste in the first update, un-official sources were pimping the big update..
Non-event, MS will deliver on their "pre-launch" promises.![]()
Why oh why didn't I get an Iphone or Android![]()
