5 years out of a PSU?
9 Dec 2009
Bristol
Is this a fair estimate before seeing about a replacement?
Bought an OCZ 600W Stealth Xtreme in mid 2007, of course as time has passed it's been working harder as I've uprgraded other components & pushed my overclock further. Voltages under load still look good in HW monitor.
The reason I ask is when they die they can take out other components & if I need to get a new PSU now to avoid this I will, however I still want to get the most out of this one. If I could afford an upgrade to new technology I would do so.
According to a PSU calculator I'm using 513 watts with my current system, I want to try & get another 18mths - 2yrs without upgrading anything else so would my current 3 & a half yr old PSU be good for another couple of years?
I think it is unlikely that you would ever draw 513 watts with your system. So I agree that you should be fine with it for a while longer.
Using a 10 year old Tagan 480W here, still works (touch wood!).
When a PSU dies it should not take out components...
500+W is a lot of juice, instead of using an online calculator you are much better off measuring how much power your system is using. Most systems pull less than 400W from the mains...
When I heard my six year old 350w seasonic psu squeal due to it's capacitor I knew it was dying and replaced it. I think you should be fine unless there is reason to replace it
should be. PSUs will last years and years just make sure its clean and free from dust.
It's situated in an old style case & therefore at the top, the case fans must deal with most of the dust as they require frequent cleaning but the PSU fan blades are always spotless.
This is what I used to estimate my usage (coming out slightly higher this time):
I'm aware I can add up the usage of the individual components but I didn't know how much the overclock would consume.
Is the above incorrect then?
Haha that Tagan 480w would have been a beast 10 yrs ago, must have set you back a few bob :D
I've read several threads on here to the contrary, usually it's the motherboard that gets taken out too, however maybe it's just the failing PSU's which take out other components that reported.
I think it will depend on how it fails and the safety measures of the PSU.
In other words by a good brand with all the safety features you can find and then when/if it does fail will save you lots of wonga!
My new Cooler Master PSU has 5 years warranty but due to the excellent design, build quality and cooling it should last a good few years more.
Good point, just checked for warranty on this one & it is, or rather was, guaranteed for 3 yrs. Also says there is overvoltage protection so if it does go out with a bang hopefully it won't send nastiness down the wires to other components.
That is 90% TDP, which would only occur during stress testing or folding, or massive multi-tasking. So I guess it depends how often you do that, as to how accurate it is.
i used a hiper R-type 480 for 5 years only changed it last year when the fan stopped working due to dust clogging it up . then to get buy while i was looking for another pc i used to put an ice block on top of it and blow to cool it down . i realy dont recomend it but was playing scrimms most nights and was the only think i could think of doing
That psu calculator does not show the power usage of your components. It show's the reccomended wattage for a suitable psu. Your rig will be using somwhere around 300w at full load (cpu and gpu).
i have a Tagan 480W no idea how old it is though, had it for 3 years myself and i bought it from someone else :P
Is there something wrong with the wiring in my house or something?
I'm on my 5th PSU in about 6 years!
One old competitor's cheap own brand lasted about 8 months, but died peacefully.
One Antec Truepower 480W from 2005 didn't die, but did stop outputting enough power to power my gaming system after about 18 months or so. Then carried on serving in my wife's PC.
One Thermaltake Toughpower 750W died after only 5 months and took my mobo with it.
My Be Quiet! 600W lasted almost 3 years before a peaceful death.
Now using an Antec Truepower 750W and it's been going well for about 4 months (touch wood...)
I do use surge protectors (quality ones). Guess I just don't have much luck with PSUs!
The problem I found with an old psu was that it only had half the connectors I needed, only had a 20 and a 4-pin mobo connectors and no sata, or gfx so had to use various converter connectors on it. It also only had a single 16A 12v rail, which back then was pretty big, but these days they have multiple rails.
MW
Lol, are you serious? Does that mean my 10 year old Tagan 480W now only outputs out 150W? :D
It probably never outputted 480W to begin with :p.
Seriously though, they do lose a certain amount of efficiency over time, though I am damned if I can find the source of the article! My google-fu skills are weak.
