Using your mouse over rough surfaces, uneven surfaces or wood grain can ruin the user experience of a game or multiple applications. Built with gaming in mind the Qpad CT gaming pads offers a Hybratek coating, a mixture of plastic and cloth which the mouse simply glides like ice. We have these on a special pre-order price so do not miss out!
I tested the mouse for tracking on Quake Live really helped
Qpad CT Small Mouse Pad - Black ** SPECIAL PRE-ORDER PRICE ** @ £15.31 inc VAT
For all users with high demands on precision, feel and functionality this is the mouse pad that delivers. CT™ series smooth Hybratek™ coating ensures that the mouse registers every detail of the smallest mouse movement. It offers a smooth and a controlled glide with an optimum level of friction. Whether you are a hardcore gamer or work with other demanding tasks such as graphic design or large spreadsheets, you’ll thrill to the task.
- Size: Small: 28.5x20cm
- Thickness: 4 mm
- Color: Black
- Surface: Hybratek Coated soft top
Only £15.31 inc VAT.
ORDER NOW
Qpad CT Medium Mouse Pad - Black ** SPECIAL PRE-ORDER PRICE ** @ £18.37 inc VAT
- Size: Medium: 33x25.5 cm
- Thickness: 4 mm
- Color: Black
Only £18.37 inc VAT.
ORDER NOW
Qpad CT Large Mouse Pad - Black ** SPECIAL PRE-ORDER PRICE ** @ £21.43 inc VAT
- Size: Large: 40.5x28.5cm
- Thickness: 4 mm
- Color: Black
Only £21.43 inc VAT.
ORDER NOW
Qpad UC Small Cloth Gaming Surface @ £8.99 inc VAT
If you're looking for a mousepad that gives you total control while letting you enjoy working the mouse, choose QPAD's new uncoated surface mouse pad the latest in a wide portfolio of proven QPAD products. Our new, four-millimeter thick pad features a soft yet resistant surface designed to let you feel the mouse's movement over the pad's uncoated surface for better control. Portable and robust, you can roll it up, stick it your pocket and slap it down for the next game. A cross-weave rubber underside firmly grips the table where you place it. With its signature winged shape designed for an extra-wide sweet spot, UC is a superior quality soft pad that lets you do the work and gives you a sense of mastery.
- Size: 28.5x21cm
- Thickness: 3mm
- Color: Black
- Surface: Uncoated cloth surface
Only £8.99 inc VAT.
ORDER NOW
Qpad UC Medium Cloth Gaming Surface @ £11.99 inc VAT
- Size: 35x25.5cm
- Thickness: 3mm
- Color: Black
Only £11.99 inc VAT.
ORDER NOW
Qpad UC Large Cloth Gaming Surface @ £13.99 inc VAT
- Size: 42x30.6cm
- Thickness: 3mm
- Color: Black
- Surface: Uncoated cloth surface .
Only £13.99 inc VAT.
ORDER NOW
Qpad UC X-Large Cloth Gaming Surface @ £15.98 inc VAT
- Size: 50x36.5cm
- Thickness: 3mm
- Color: Black
Only £15.98 inc VAT.
PRE-ORDER NOW
Qpad heatoN Gaming Mouse pad @ £29.99 inc VAT
The pad itself has a dimension of incredible 43.5x36.5x0.35cm (17.12x14.37inch) which makes it almost impossible to slide off the edge. Previously you have only found such large pads made out of traditional cloth, but are now also available for all hard top fans out there. The surface is constructed in a 3 layer construction. Starting with a high quality cross weave rubber to make it stable on the table. The second layer is an abs plastic sheet to give it stability and weight. The third layer is made from an extremely durable carbytek plastic that offers a very good glide in combination with unique micro precision. The combination of a spongy 2mm rubber base with an abs board in between and the hard top surface gives it a new feeling never felt before. The weight of almost a half kilogram makes it very stable and firm on the table.
- Size 43.5 x 36.5 cm
- Thickness 4 mm
- Surface Carbytek technology. Hard top plastic
- Colour black
Only £29.99 inc VAT.
PRE-ORDER NOW
Qpad Grin CT Large Mouse Pad @ £23.99 inc VAT
- Thickness: 4 mm
- Grin design
Only £23.99 inc VAT.
ORDER NOW
