GeForce Beta Driver Release 266.35
With 263.09 I was getting 6 FPS in this circumstances, even if it had a few more models then, this is a huge improvement in FPS, getting at least 3x the performance here.
Just FYI this game is 8 yrs old.
That's great, not only do you fail to mention your specs and the game your playing, but you also proceed to hurt my eyes with HUGE 2560x1440 screenshots and some of the worst textures I've seen for a long while!
Can you please resize the pix? or alternatively I'm sure an explanation of the game with increases in performance would do just fine, kthxbai :)
All seems good so far. GTX580 SLI gained 6fps in Heaven @ 1920x1200, and everything else plays exactly as it did beforehand (perfectly). Still no SLI support for 3DMark11.
i7 950 @ 3.9 ghz
GTX 570 @ 900 mhz
Game is Final Fantasy XI. I'm posting for anyone who plays it because one of the issues these drivers fix is the horrible performance for this 8 yr old PS2 port.
* Improves performance in Final Fantasy XI on GeForce 400 Series and 500 Series GPUs.
Also people who care about the performance in this game, which are the people I posted for, would have noticed the game straight away. It doesn't matter to me if you don't. You wouldn't ask for the name of a Crysis screenshot because it's probably blatently obvious to you. However I only really needed to get this across to people who will actually take advantage of it.
i7 950 @ 3.9 ghz
GTX 570 @ 900 mhz
That's all wonderfull, and I'm sure the people that still play FF XI are most appreciative of your testing, but do we really need to have the massive screenshots?
It's not too bad viewing on a 1080P monitor but can you imagine viewing @ 1280x1024 for example?
You don't have to get rid of the screenshots merely resize them to something more forum friendly :)
Some fine performance increase right there.
What's the problem, it's not stretching the posts. I can read every ones posts fine I just can't see all the awful GFX in the screens which is a good thing.
It's utterly pointless! and for anyone viewing on a phone it's just downright rude with each image being 2.5MB!
All it takes is 5 seconds in paint to resize!
I resized them.
Also it seems I forgot to reset clock speeds after updating drivers, that 6 FPS I usually got was @ 900, the 19-20 FPS was at stock, 732.
With 900 hz it's slightly higher, maybe 23-24.
3D actually works properly with these now since they included an updated 3D controller driver, i had to manually install it though
edit: vietnam runs like butter, 1080p, 4xaa, 16xaf, dx 11, 3D vision with just hbao and bloom disabled, averages like 45-50fps on hastings on a single gtx 480, extremely impressive performance
These drivers have improved my GTX 570 minimum fps by a far margin. Also, my gpu usage has gone up in older games! :)
For example GTA4, took a couple of seconds to reach to its average fps, now it hits it in under a second :)
How does it average 45-50fps? When you run 3d vision V Sync is locked at 60hz?
