Here are our This Week Only deals, some fantastic price drops on great products. Do not forget we pay the VAT increase with our special discount code!
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black @ £129.98 inc VAT
The Antec Twelve Hundred is the evolution of the best-selling Nine Hundred, expanding on its award-winning design with even more cooling, capacity, and convenience. The Twelve Hundred is incredibly robust, with 12 drive bays, 7 expansion slots, and space for even the largest graphics cards. To keep the most demanding systems nice and cool, the Twelve Hundred boasts an unprecedented cooling system, with a top mounted 200mm blue LED fan, two rear blue LED 120mm fans, and three front blue LED 120mm fans to cool the HDD cages. Factor in convenient features like front mounted USB, eSATA, and HD audio ports, and the Twelve Hundred obliterates the competition.
- 12 Drive Bays
- 7 expansion slots
- Advanced cooling system
- No power supply included
- Motherboard: Up to standard ATX
- Top mounted I/O ports for easy access
- Perforated front bezel for maximum air intake
- Washable air filters reduce dust build up in your system
- Convenient top accessory tray for a personal media player
Was £137.86 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Arctic White @ £87.98 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £94.97 Inc. VAT
Only £87.98 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 PC3-16000C9 2000MHz Triple Channel Kit (CMX6GX3M3B2000C9) @ £119.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i7 triple channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 9-10-9-27
- Pin Voltage: 1.65V
Was £126.62 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Antec High Current Gamer 400W Power Supply @ £46.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The
High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors
and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
Was £50.03 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
Corsair Dominator 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (CMP6GX3M3A1600C8) @ £119.99 inc VAT
The DOMINATOR is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair DOMINATOR only uses highly screened IC’s to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the DOMINATOR modules can even be outfitted with additional upcoming accessories with enhanced features.
- Outrageously fast 1600MHz performance
- Ultra-low 8-8-8-24 latency
- Intel XMP (Extreme Memory Profile) Support
- Includes new connector for future upgrades and accessories
- Limited Lifetime Warranty
Was £127.64 Inc. VAT
ORDER NOW
GeIL 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel (GVP312GB1600C9TC) @ £134.39 inc VAT
GeIL announces the launch of the all new DDR3 Value PLUS & Ultra PLUS Series to be added to GeILs’ high performance memory line of products. The Value PLUS & Ultra PLUS are equipped with the latest PLUS Edition memory heat-spreader designed with heat-sink surface and extended height for maximum cooling efficiency. The Ultra PLUS line of memory will be carrying over-clocking performance while the Value PLUS line has the more stability-oriented specifications. As GeILs’ quality standard, both series will be enhanced with DBT – Die-hard Burn-in Technology for the highest quality assurance.
- PC3-12800 1600MHz CAS 9-9-9-28
- 240pin, Non-ECC, Un-buffered DDR3 DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- 1.5V-1.6V Power Supply
- Lifetime Warranty
- DBT - Die hard burn-in technology (Improved reliability)
Was £139.99 Inc. VAT
Only £134.39 inc VAT.
ORDER NOW
GeIL 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel (GVP36GB1600C9TC) @ £59.99 inc VAT
- PC3-12800 1600MHz CAS 9-9-9-24
- Lifetime Warranty
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Antec High Current Gamer 520W Power Supply @ £56.99 inc VAT
Was £61.26 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
GeIL 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP38GB1600C9DC) @ £91.90 inc VAT
- Lifetime Warranty
Was £94.99 Inc. VAT
Only £91.90 inc VAT.
ORDER NOW
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) @ £38.39 inc VAT
- Lifetime Warranty
Was £41.99 Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £74.39 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £81.70 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
GeIL 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel (GX22GB6400UDC) @ £33.59 inc VAT
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 1GB and 2GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Lifetime Warranty
- 1.9V-2.3V Power Supply
Was £35.99 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Antec High Current Gamer 620W Power Supply @ £68.99 inc VAT
Was £73.52 Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
GeIL 4GB (2x2GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel (GX24GB6400C4UDC) @ £55.19 inc VAT
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 2GB and 4GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- Lifetime Warranty
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £233.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £239.99 Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £299.99 Inc. VAT
Only £287.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card with FREE MOH Game @ £143.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6850 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6850 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
This high-speed graphics card outdoes the competition with 775MHz, a 4 GHz memory clock, DP + HDMI + Dual DVI which allows for play across four screens and a shader speed of 800 to ensure that graphics are crisp and life-like.
Along with the new series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD’s HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
The AMD Radeon HD 6850 offers no compromise performance with flawless image quality so users aren’t just playing the game – they’re in it.
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Processing Cores: 960
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1x DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FREE Download of Latest Medal of Honor PC-Game when you register product with XFX, see inside packaging for download instructions
Was £151.14 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card with FREE MOH Game @ £185.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
- Core Clock: 900MHz
- Memory Clock: 4200MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £191.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI CrossFireX Ready
- ATI Avivo HD
- Warranty: 2 Years
Was £120.50 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £104.16 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Palit GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 2 years
Was £289.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Exclusive Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 768MB GDDR5
- Memory Clock: 3680MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £122.54 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 1024MB DirectCU TOP GDDR5 PCI-Express Graphics Card @ £161.99 inc VAT
- ASUS Exclusive DirectCU Thermal Solution: Three 8mm flattened copper heat-pipes contact GPU directly and reach up to 20% COOLER than generic GeForce GTX460
- Over-clocked with 775 MHz engine clock for reaching 115% performance
- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Memory Interface: 256-Bit
- Shader Clock: 1550MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £173.60 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £113.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
ORDER NOW
OCZ Vertex 2E Bigfoot 240GB 3.5" SATA-II Solid State Hard Drive @ £311.99 inc VAT
OCZ Vertex 2 SATA II 3.5” Solid State Drives deliver the same industry-leading performance as the 2.5” edition in a larger, lower cost per gigabyte form factor to easily integrate into desktop applications without the need to install additional hardware.
Designed to excel in both sequential and random read/write speeds up to 50,000 4KB random write IOPS, the 3.5” Vertex 2 maximizes productivity when used as a primary storage or boot drive, minimizing program load times and completing tasks with blazing speed. Using the latest controller technology, the 3.5” Vertex 2 provides a faster, more responsive PC experience complete with TRIM support to keep your drive operating at peak performance in Windows 7 systems. Built with SATA 3Gb/s, Vertex 2 3.5” drives easily integrate into today’s desktop platforms as the ultimate storage upgrade.
Features:-
- Max Read: up to 285MB/s
- Max Write: up to 275MB/s
- Sustained Write: up to 250MB/s
- Random Write 4KB (Aligned): 50,000 IOPS
- Available in 90GB to 480GB capacities
- Native TRIM support
- Max IOPS Firmware
- Seek Time: .1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 25.40mm (H)
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation,.5W in standby
- Shock Resistant up to 1500G
- RAID Support
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- 3-Year Warranty
Was £326.80 Inc. VAT
Only £311.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £323.99 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £347.22 Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
OcUK Cream 18.5" Widescreen LCD Monitor - Glossy Black @ £71.99 inc VAT
This OcUK Value 18.5" monitor has an industry leading ultra-fast 2ms response time making it perfect for blur-free video and gaming. With it's 2000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
- Screen Size: 18.5" Widescreen
- Resolution: 1360x768
- Contrast Ratio: 2000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 444.0mm x 324.0mm x 170.5mm
- Weight: 3.2kg
- Warranty: 3 Years On-Site
Was £81.70 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Samsung B1930N 18.5" Widescreen LCD Monitor - Glossy Black @ £89.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 50000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 250cd/m² and you have a monitor that is made for multimedia.
- Contrast Ratio: 50000:1
- Response Time: 5ms
- VESA Compliant
- Dimensions: 455.6mm x 375.0mm x 178.0mm
- Weight: 3.35kg
Was £102.12 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Samsung BX2235 21.5" Widescreen LED Monitor - Mystic Black @ £137.99 inc VAT
It’s not an illusion, each Samsung monitor’s 2-millisecond response time makes faster, clearer images a reality. No matter how quick the action gets, this monitor keeps up with the scene, delivering stunning, seamless motion imaging that enhances your movie viewing, game playing and internet streaming experience. There’s no juddering, blurring or ghosting, just smooth viewing that you can totally immerse yourself in. With Magic Speed, finally magic you can believe in.
There’s dynamic and then there’s Mega Dynamic. With an upgraded contrast ratio – the highest level of contrast ratio currently available - Samsung monitors deliver professional picture quality that makes colours more rich and real then you’ve dreamt possible. So real, you’ll see each eye-popping colour and crystal-clear detail come to life right on your screen.
Why should seeing the whole picture be a stretch, or for that matter, a distorted facsimile of the original? With Samsung’s intelligent adjustable image size function, you’ll be able to enjoy images exactly as they were intended, by portraying standard sized content in its original format, on a wider screen.
Magic Eco makes saving energy easy. It adjusts Samsung monitor’s brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off’. If Magic Eco is turned off, you still enjoy the option of using Samsung’s Magic Bright feature, engineered to let you manually adjust the screen’s brightness. Take the effort out of saving energy and take control with Magic Eco.
Samsung Monitors aren’t just high performers. They’re eco-friendly, efficiency experts as well. The automatic off timer allows users to save energy by setting the monitor to turn itself off at a specified time. As an added benefit, this ensures optimal performance for lasting reliability and extended life.
Magic Angle creates the perfect viewing position when you are lying down. By recreating the image purity that you see when viewing the screen from the front, Magic Angle makes entertainment more comfortable. When returning to a normal viewing position, Magic Angle should always be turned off to ensure ocular comfort.
Samsung’s innovative custom key feature puts enhanced entertainment at your fingertips, literally. By allowing you to assign your favourite function to the customised key, your favourite features are accessed in a flash. Will your customised key bring you Magic Bright, Magic Colour, Colour Effect, or the Image Size function? The beauty is, you decide.
Enhance images your way using Samsung’s advanced ColourEffect feature. Open your eyes to a completely customised viewing experience as you play with photographic effects that match your mood. Choose from Aqua, Sepia, Green and Greyscale to interact with your display in a whole new way – namely, yours.
Features:-
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 500000:1
- Weight: 3.55kg
Was £143.99 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
ViewSonic VP2365wb 23" Premium IPS Panel Widescreen LCD Monitor @ £203.99 inc VAT
The VP2365wb is one of ViewSonic’s new LCD Professional Series monitors that utilizes the power of IPS panel technology. With IPS true colours, high contrast ratio and wide viewing angles coupled with 1920x1080 Full HD resolution, the VP2365wb is the perfect solution for designers, manufacturers, medical applications and movie production. A 4-port USB hub for cluster free connectivity, ergonomic functions with pivot, height adjust, tilt, swivel and slim bezel make the VP2365wb a feature-packed monitor.
- Screen Size: 23" IPS Widescreen
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 14ms
- Viewing Angles (H/V): 178°/178°
- 4-Port USB 2.0 Hub
- VESA Compliant
- Dimensions: 548.0mm x 433.0mm x 250.0mm
- Weight: 6.8kg
Was £215.99 Inc. VAT
Only £203.99 inc VAT.
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £146.39 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Was £153.18 Inc. VAT
Only £146.39 inc VAT.
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £177.59 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Was £183.82 Inc. VAT
Only £177.59 inc VAT.
ORDER NOW
Sony VAIO F12 MOE/B 16.4" True HD LED TFT Intel I7-740QM, 4GB DDR3, 500GB HDD, Blu-Ray, NVIDIA GT330M, Win7 Home Premium 64-Bit @ £881.99 inc VAT
Just like the Z-series, the F12 packs a boatload of impressive specifications, but rather than cramming them into as small a chassis as possible, this 16.4in laptop - measuring 263 x 41 x 387mm and weighing 3.1kg - sits firmly in the desktop replacement category. Gamers aside, it has plenty of power to be most consumers' primary machine. At its heart is an impressive 1.73GHz 740QM Intel Core i7 quad-core CPU which turbo-clocks to 2.93GHz. This is backed by 4GB of DDR3 RAM, which is as much as most users will need and plenty for the supplied 64-bit Windows 7 Premium to be happy with.
For storage there's a generous 500GB hard drive that spins at a speedy 7,200rpm, while optical duties are handled by a Blu-ray drive. Combined with the screen's 1,920 x 1,080 resolution and an Nvidia GeForce GT 330M graphics card, this makes for a very capable multimedia machine that should also have a modicum of gaming ability.
Connectivity is also well up to speed. For wireless duties we have Wi-Fi N and Bluetooth 2.1, with the always-appreciated addition of a physical wireless switch. There are three USB 2.0 ports, one of which doubles as an eSATA connector. Then there's a four-pin mini FireWire port, which is becoming quite the rarity these days.
Other data ports, including USB 3.0, can be added through the laptop's 34mm ExpressCard slot, while two separate memory card readers take Sony's proprietary MS Pro and the more common SD/MMC card formats. Finally for video we have HDMI and analogue VGA, while audio is handled by 3.5mm headphone and microphone jacks, the former of which doubles as an optical digital output.
This stunning Sony Vaio F2 series laptop gives you a top of the range performance on all your computing and multimedia tasks.
Bypass booting up and get online instantly with one touch of the 'WEB’ button. Multi-task easily on the large 16.4in HD (1920 x 1080) display, which is also perfect for spectacular viewing of high-definition movies via the built-in Blu-ray drive. An up-to-date Intel Core i7-740QM processor and 4GB memory give you a great performance every time - multitask or play your favourite games knowing your laptop won't grind to a halt. The glistening black finish and slimline design mean this Sony Vaio F2 series laptop is as stylish as it is powerful. A 500GB hard drive gives you plenty of storage place for all your MP3s, photos and files. Stay in touch with friends and family across the world via Skype using the built-in webcam and microphone. Organising your favourite photos and videos has never been easier - now you can create professional-looking movies to share with family and friends in just three easy steps.
A new 'ASSIST' button gives you instant access to Vaio Care, with help easily available to recover and restore files and to diagnose or troubleshoot your Sony Vaio F2 series laptop.
Features:-
- 3D Mark 2006 Score of 6750 points (Ideal for Good Gaming Experience)
- Intel Core i7-740QM processor (Upto 2.93GHz Turbo Mode)
- 4GB DDR3 RAM
- 500GB 7200RPM hard drive
- 16.4in Vaio HD display (1920 x 1080; 16:9)
- Blu-ray Disc ROM drive with DVD SuperMulti
- NVIDIA GeForce GT 330m GPU graphics
- 802.11 a/b/g/n
- Built-in Motion Eye digital camera
- Bluetooth 2.1+ EDR
- Gigabit Ethernet
- HDMI & VGA Connections
- 3-in-1 Card Reader
- Weight: 3.1kg
- Windows 7 Home Premium
- Brand new sealed product, full 2yr Sony Warranty
Was £969.19 Inc. VAT
Only £881.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I5-460M, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,018.80 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Core i5-460M 2.53GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i5 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i5-460M 2.53GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
- - 3D Mark 2006 Score of 12750 points (Ideal for Maximum Gaming Experience)
Was £1,078.80 Inc. VAT
Only £1,018.80 inc VAT.
ORDER NOW
Cooler Master Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) @ £11.99 inc VAT
Cooler Master's Hyper TX series has evolved with requirements of current mainstream CPUs. The introduction of Hyper TX3 marks another milestone with Cooler Master's first-ever full compatibility with Intel LGA 1156 socket.
Hyper TX3 is taking basic ideas and simple design while incorporating it with most of the fine points of a decent performing cooler, such as the flexibility to switch from Intel to AMD quickly and easily, the dual fan design to attach another 92mm fan to increase the cooling power. Hyper TX3 also brings back the "original" direct contact heat-pipe design from Cooler Master.
- Flexible mountings for Intel Socket LGA 775/1156 and AMD Socket 754/939/940/AM2/AM3.
- Maximum compatible CPU wattage: over 130W TDP.
- 3 x Direct Contact heat-pipes with aluminum fins to provide excellent heat dissipation.
- Option for adding 2nd fan to increase cooling performance.
- New 92mm PWM fan with wide RPM range and anti-vibration rubber pads.
- Silent CPU cooler at only17 dBA (at minimum speed).
- Easy swappable fan by clips (clips for 2nd fan included).
- Excellent airflow design with compact heatsink dimension.
Was £13.26 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £96.98 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Only £96.98 inc VAT.
ORDER NOW
MSI X600 Ultra Thin 15.6" WLED TFT, Intel SU4100, 4GB RAM, 500GB HDD Windows 7 Home Premium - Black @ £418.80 inc VAT
MSI has launched a new laptop to meet the ever-increasing demands of our mobile needs. The unveiling of its brand new line of ultrathin notebooks is a milestone both technologically and aesthetically. This innovativly-thin laptop has completely revolutionized the idea of a portable computer; its sleek yet simplistic lines fit seamlessly into its polished exterior, raising the bar for thin-notebook design a step higher.
The design of the X600 strives to be literally, as light as a feather, and, as thin as one too. Its near weightlessness and ultra thin exterior has fused graceful design and trendsetting style. Perhaps the most stunning aspect of this laptop is that in entirety, it weighs a mere two kg. It is undoubtedly the world’s lightest and thinnest 15.6-inch laptop. The X600, although thin, has not compromised its technology in the slightest; it is precision design, down to the last detail.
The X600 embeds ATi Mobility Radeon HD 4330 3D graphics card with 512 MB VRAM, providing support for millions of colors, brilliant detail and breathtakingly vivid effects. The 15.6-inch LCD widescreen glossy display makes watching high definition DVDs or gaming a real pleasure, as it brings you one step closer to your viewing experience.
The 16:9 theater ratio can provide bigger visual area. When watching movies, the black bars on the top and bottom of the 16:10 aspect ratio screen can also be avoided. This is perfect for playing HD videos at any possible angle, absolutely ideal for visual enjoyment.
The X600 is embedded with LED power-saving backlight technology to provide better color fullness and brightness, elevating the total quality of imagery. Furthermore, the lower usage of power can offer a longer operating time.
MSI exclusive VIVID technology is able to display signals that allow for richer colors, making the X600 has one of the most stunningly dramatic screens on the market, bringing even the smallest details to life. Regardless of whether you’re gaming, editing images, or simply watching movies, your experience will be incredibly realistic.
Features:-
- Intel SU4100 1.30GHz Processor
- 4GB of Memory
- 500GB HDD
- 15.6” 16:9 Wide Screen Display (1366*768)
- The Very Best Expression of Slim Aesthetic
- ATi Mobility Radeon HD 4330 Graphics Card with 512 MB VRAM
- MSI Exclusive EDS (Ergonomic De-Stress) Keyboard
- Advanced Power Saving Technology
- Theater Class 4 Speakers Qualified by Latest Dolby® Surround
- WiMAX™ Wireless Module (optional)
- HDMI (High-Definition Multimedia Interface) Output
- Built-In High Resolution Mega Pixels Webcam
- 802.11b / g / n Wireless Lan with Bluetooth (optional)
- 6 Cell Battery (upto 8hr battery life)
- 2 years Warranty
Was £478.80 Inc. VAT
Only £418.80 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 250GB SATA-II 8MB Cache - OEM (ST3250318AS) @ £26.95 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 250GB of high-performing, eco-friendly digital storage.
- Capacity: 250GB
- Cache: 8MB
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £28.58 Inc. VAT
Only £26.95 inc VAT.
ORDER NOW
MSI X340 Ultra Thin 13.3" WLED TFT, Intel SU4100, 2GB RAM, 320GB HDD Windows 7 Home Premium - White @ £335.99 inc VAT
The X340 has ingeniously applied fashionable curves in its design which successfully abandoned the cold and lifeless vibe of the traditional notebook computers. The material is gentler to the touch compared the metal, and the paint finish is glazed and UV processed, added with the perfect ratio as a total package, creating the most simplistic yet modern styling, fitting for the most contemporary trend anywhere. With all these unique features, it proves that the X340 is not only a fashionable and appealing notebook computer; it also set very high marks for the entire industry. These great reasons are why the X340 should be highly recommended to all of the contemporary metropolitans anywhere. The X340 has selected the 13 LCD display as oppose to the 12” or even smaller sizes. This provides much more comfort in reading and operation as well as less weight restraints compared to the 14 models. The 16:9 theater ratio can provide bigger visual area. When watching movies, the black bars on the top and bottom of the 16:10 aspect ratio screen can also be avoided. This is perfect for playing HD videos at any possible angle, absolutely ideal for visual enjoyment. The X340 is embedded with the LED power-saving backlight technology in providing better colour fullness and brightness, elevating the total quality of imagery. Furthermore, the lower usage of power can offer a longer operating time. The Vivid Technology can enhance the richness in colours from the source of the signal so the images displayed can provide more levels and details. This also gives a more three-dimensional expression during gaming, watching movies or viewing pictures, and even during the editing process. X340 is also equipped with the exclusive ECO Engine power management system, so you can select freely from the five different modes suitable at your convenience. The five modes include office, gaming, movies, presentation, and turbo battery. Through varies conditions such as the brightness of the screen and standby timeframe, the power consumption can be much more flexible, providing more hours of operating time. This escalates the productivity of the X340 as well as convenience for our users.
The X340 features the latest Intel Centrino Processor Technology, which uses Intel Core2 Solo ULV Processor and Intel GS45 + ICH9M-SFF Chipset, to deliver long battery life, innovative mobile solutions with unrivaled processor performance, stunning new HD capabilities, and great wireless connectivity (Integrated WiFi+ optional WiMAX, up to 450mbps 802.11 b/g/n). HDMI Digital Terminal Interface offers more than 5 GB of transmitting bandwidth; it also lessens the complications of cables. The X340 offers the very best in image quality through the HDMI Terminal so it may have the most realistic picture perfection. The X340 is embedded with a high pixel webcam incorporated with the design of the notebook for a slick and technological appearance. The user may broadcast live during teleconferencing, capturing and recording every exciting moment. Great quality and richness in colours when taking photos both indoors and out adding even more excitement. The X340 is also embedded with the IEEE 802.16e WiMAX(Worldwide Interoperability for Microwave Access)wireless module, which highly elevated the variety of wireless internet service, allowing the online experience to be faster and more mobile. Regardless if you’re in the coffee, shops, school campuses, offices, or airports, you may access the world through WiMAX, never missing the latest information. Other than the WiMAX feature, the X340 also processes the 802.11b /g/n Wi-Fi wireless internet access, so you can have all the internet functions fulfilling a mobile lifestyle. The X340 also provides Bluetooth capability which can be connected to cellular phones, earphones, PDA, and other gadgets, say goodbye to the fuss of lines and cables forever. The X340 has provided a complete entertainment interface which includes a 2 in 1 card reader (supports SD/MMC), varies mainstream memory sticks, making it easy inputting data into the notebook computer. Also applicable to many digital products such as digital video and photo cameras, MP3 Players and others, which can all be connected to the X340 Pro through USB 2.0 port. External DVD Burner is also available (optional) so you can play DVD movies or burn important documents
Features:-
- 2GB of Memory
- 320GB HDD
- 13.3” 16:9 Wide Screen Display (1366*768)
- Intel GMA 4500MHD Graphics
- 4 Cell Battery (upto 8hr battery life)
- 2 years Warranty
Was £408.50 Inc. VAT
Only £335.99 inc VAT.
ORDER NOW
Dell Inspiron 1011 Intel Atom N270 1.60GHz 10.1" LED, Mini Netbook (Obsidian Black) - Windows 7 @ £197.99 inc VAT
Timing is everything, and now you can have all the time in the world. The newly designed Inspiron Mini 10 offers up to 8.5 hours of battery life to keep you on the go. This Dell Inspiron Mini Netbook features a 160GB hard drive, plenty of room to store all your photos and music. It also features a webcam so you can communicate with friends or family from miles away, or use it to take images of yourself to upload on to the net. If you're looking for a small, lightweight, great quality Netbook for general web browsing, emailing and keeping your photos safe then the popular Dell Mini Inspiron Netbook is for you!
- Intel Atom N270 1.60GHz Pineview Processor
- Display: Built-in 10.1" WSVGA TrueLife widescreen display (1024 x 600)
- 1GB RAM
- 160GB Hard Drive
- 3 in 1 Card Reader
- 3 Cell Battery
- 3x USB2.0
- Windows 7 Starter
- 12 Months Warranty
Was £229.78 Inc. VAT
Only £197.99 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Was £255.31 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Iiyama ProLite E2607WS 26" Widescreen LCD Monitor - Black @ £227.99 inc VAT
The new flagship product from Iiyama is the E2607WS, a High Definition, 2ms 26” LCD solution perfect for today’s demanding applications. Superb colour quality is achieved by a 4000:1 Advanced Contrast Ratio. The OptiColour features allows quick and simple adjustment of the colour settings to suit the application or mood. 5 Watt speakers offer Stereo Audio performance well above the average multimedia display available today. The three input configuration of HDMI, DVI and Analogue guarantees compatibility with the flexibility to switch between multiple sources.
- Screen Size: 26" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 4000:1
- Viewing Angles (H/V): 170°/150°
- Dimensions: 597.5mm x 460.5mm x 238.0mm
- Weight: 8.3kg
Only £227.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 500GB SATA-II 16MB Cache - OEM @ £29.16 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 500GB
- Cache: 16MB
- Warranty: 3 Years
Was £30.62 Inc. VAT
Only £29.16 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £41.03 inc VAT
- Capacity: 1TB
- Cache: 32MB
- Warranty: 3 Years
Was £43.91 Inc. VAT
Only £41.03 inc VAT.
ORDER NOW
Hitachi Deskstar 7K2000 2TB SATA-II 32MB Cache - OEM (0F10311) @ £91.19 inc VAT
The Deskstar 7K2000 hard drive delivers a colossal two terabytes of storage capacity and 7200RPM performance in a standard 3.5" form factor. Now in its fourth-generation, the 7K2000 is based on a robust mechanical design that continues to set the industry standard for quality and reliability. The Deskstar 7K2000 offers an exceptional blend of capacity and power efficiency, with idle power savings over previous generation products up to 10%. On a watts per gigabyte basis, idle power has improved over 120%. Leveraging eighth-generation power management technology, including power-saving innovations like HiVERT technology, this drive delivers best-in-class power management and thermal emissions to help manufacturers meet energy compliance targets and extend drive life.
- Capacity: 2TB
- Cache: 32MB
- Warranty: 3 Years
Was £96.98 Inc. VAT
Only £91.19 inc VAT.
ORDER NOW
Western Digital Caviar Green 1TB SATA-II 64MB Cache - OEM (WD10EARS) @ £43.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 1TB
- Cache: 64MB
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £45.95 Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £76.99 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 5 Years
Was £79.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £68.99 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Was £71.48 Inc. VAT
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £24.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £26.54 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard @ £60.67 inc VAT
The GA-880GM-UD2H introduces revolutionary Gigabyte Ultra Durable 3 Classic technology on AMD platform featuring a 2oz copper PCB and further helps to reduce the system temperature and dramatically enhance the performance. Based on AMD 880G chipset, the GA-880GM-UD2H is integrated ATI Radeon HD 4200 (DX10.1) graphics engine and supports AMD Phenom II quad-core processors, DDR3 memory modules, HyperTransport 3.0 technology links, PCI Express 2.0 graphics interface and more. With the innovative Gigabyte Easy Energy Saver technology, GA-880GM-UD2H is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- CPU: AMD Phenom II/Athlon II Series Processors (Socket AM3)
- Chipset: AMD 880G / SB710
- System Bus: Up to 5200 MT/s HyperTransport 3.0
- Memory: 4x DDR3 DIMM 1800(OC) / 1666 / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Integrated ATI Radeon HD 4200 GPU
- Expasion slots: 1x PCIe 2.0 x16 Slot, 1x PCIe x1 Slot & 2x PCI Slots
- Storage: 1x Ultra DMA 133/100/66, 5x SATA 3Gb/s (RAID 0, 1 and 10) & 1x eSATA 3Gb/s
- LAN: RTL8111D Gigabit LAN
- Audio: ALC892 8-channel High Definition Audio CODEC
- 12x USB 2.0
- 2x IEEE 1394a
- 1x PS/2 COMBO (Keyboard & Mouse)
- 1x S/PDIF Out (Optical)
- 1x HDMI
- 1x DVI
- 1x D-SUB
Was £71.47 Inc. VAT
Only £60.67 inc VAT.
ORDER NOW
Asus Rampage III Extreme Intel X58 (Socket 1366) DDR3 Motherboard @ £276.98 inc VAT
Asus Republic of Gamers reveals the latest addition to their roster of performers, the world-record shattering Rampage III Extreme. Delivering Intel's X58/ICH10R chipset with support for the Intel processors in the LGA1366 package up to six cores and a plethora of features demanded by intense users, this board is the only choice for PC speed demons. Remote tweaking becomes effortless thanks to built-in ROG Connect and RC Bluetooth, giving users the freedom to unchain true hardware potential. Rampage III Extreme contains the latest iteration of Extreme Engine Digi+ voltage modulation technology for purer, more stable power. The OC Kit strikes a formidable pose as an interface to meet the strenuous requirements of even the techiest overclocker, with LN2 mode and a Q reset that addresses cold boot problems and enables fast operation even under very low temps during extreme overclocking.
- 2x USB 3.0
- 2x SATA 6Gb/s
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express / ICH10R
- Memory: 6x DDR3 DIMM 2200(OC) / 2133(OC) / 2000(OC) / 1800(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 4x PCIe 2.0 x16 Slots, 1x PCIe x4 Slot & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA 3-Way SLI Technology)
- Storage: 7x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 1x eSATA 3Gb/s
- LAN: Intel Gigabit LAN
- Audio: 8-channel High Definition Audio CODEC
- Bluetooth V2.0/V2.1+EDR Card
- 9x USB 2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- Extreme Engine Digi+
- USB BIOS Flashback
- ROG Connect
- ROG Extreme OC Kit
- Extreme Tweaker
- iROG
- ProbeIt
- ASUS Q-LED
- Loadline Calibration
- Q-Fan Plus
- ATX (305.0mm x 269.0mm)
Was £296.15 Inc. VAT
Only £276.98 inc VAT.
ORDER NOW
Gigabyte GA-X58-USB3 Intel X58 (Socket 1366) DDR3 Motherboard @ £120.00 inc VAT
Based on the Intel X58 chipset, the Gigabyte GA-X58-USB3 delivers all the killer next generation features that gaming enthusiasts and power users have been waiting for including Gigabyte's 333 Onboard Acceleration features with support for USB 3.0 and a 3x USB Power Boost, as well as multi-GPU support for NVIDIA 3-Way SLI and ATI CrossFireX and support for Intel's high performance processors offering a high level of future CPU headroom for users wanting to maintain cutting-edge levels of performance. With the memory controller integrated directly into the processor die, the Gigabyte GA-X58-USB3 also supports triple channel DDR3 memory for blazing fast memory performance.
- 2x USB 3.0
- Memory: 6x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 1x PCIe 2.0 x16 Slot (running at x4), 3 x PCI Express x1 slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 8x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- Audio: ALC889 8-channel High Definition Audio CODEC
- 6x USB 2.0
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
Only £120.00 inc VAT.
ORDER NOW
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard @ £142.25 inc VAT
This motherboard supports the latest Intel Core i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. The P6X58D-E breaks the boundaries to bring you the multi-GPU choice of either SLI or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability.
- Memory: 6x DDR3 DIMM 2000(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 1x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Coaxial)
- 16+2 Phase Power Design
- TurboV
- MemOK!
- EPU
- Express Gate
- Fanless Design
- Stack Cool3+
- CrashFree BIOS 3
- EZ Flash 2
- MyLogo 2
Was £153.05 Inc. VAT
Only £142.25 inc VAT.
ORDER NOW
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard @ £99.98 inc VAT
This motherboard supports the latest Intel Lynnfield and Clarkdale processors, which have the memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes, enabling higher graphics performance. Supporting the next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0Gbps data transfer rates. Experience ultra-fast data transfers at 5Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10 times faster and is also backward compatible with USB 2.0 devices. Turn on IO Level UP to boost the USB 3.0 or SATA 6Gb/s data transfer rate to up to 500MB/s. Users can flexibly switch between full-speed PCIe x16 mode for their graphics cards and IO Level UP for rapid data throughput.
- CPU: Intel Core i7/Core i5 Processors (Socket LGA1156)
- Chipset: Intel P55 Express
- Memory: 4x DDR3 DIMM 2200(OC) / 1600 / 1333 / 1066 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 3x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Ultra DMA 133/100/66, 7x SATA 3Gb/s (RAID 0, 1, 5 and 10), 2x SATA 6Gb/s & 1x eSATA 3Gb/s
- LAN: RTL8112L Gigabit LAN
- Audio: VT1828S 8-channel High Definition Audio CODEC
- 2x IEEE 1394a
- 12x USB 2.0
- 2x USB 3.0/2.0
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- TurboV EVO
- T.Probe Technology for Active Cooling
- ASUS 12+2 Phase Power Design
- Quad-GPU CrossFireX Support!
- MemOK!
- EPU
Was £108.24 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Thermaltake Frio CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £36.98 inc VAT
The Thermaltake Frio has excellent cooling capacity supporting 220W with 0.5mm aluminum fins that have a large surface for heat dissipation. It's 5x U-shaped copper heat pipes provide accelerated heat conduction through this tower side flow designed cooler.
It efficiently optimizes cooling performance with 120 mm VR fans, adjustable between 1200 and 2500 RPM max. for best overclocking performance. As well as being universally compatible it comes with some premium thermal grease to maximize heat transfer from the CPU into the cooler copper base for rapid dissipation
- Ultimate Overclocking Thermal Structure Design
- Ultra Powerful Dual 120mm VR Fan and Eye-Catching Cover
- Universal Socket Compatibility & Accessory Package
- Supports up to 6 Core Processors
- Socket Compatibility: LGA1366/LGA1156/LGA775/AM2/AM2+/AM3
- Fan Speed: 1200 - 2500 RPM
- Air Flow: 101.6CFM
- Noise Level: 20 - 43 dBA
Was £39.82 Inc. VAT
Only £36.98 inc VAT.
ORDER NOW
"Primo Trinity" Intel Pentium Dual Core E6500 2.93GHz DDR3 System @ £229.99 inc VAT
The "Primo Trinity" features the excellent value Intel Pentium Dual Core E6500 2.93GHz processor, combined with a selection of high performance yet excellent value, handpicked components designed to meet your desire for the home office or work system.
Why You Should Buy This System?
- The Dual Core E6500 is perfect for multi-tasking applications in the home or office environment
- Small and silent making it the ideal home office or work system
- Large capacity 500GB hard giving you plenty of room for storage
- Precision built and cabled by Overclockers UK expert technicians
System Specification
- Case: OcUK Hades Micro ATX Case
- Power Supply: OcUK Value 450W Power Supply
- CPU: Intel Pentium Dual-Core E6500 "LGA775 Core 2" 2.93GHz
- Motherboard: MSI G41M-P25 Intel G41 (Socket 775) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 Dual Channel
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Onboard Intel GMA X4500 Graphics
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: 22x DVD+RW SATA Dual Layer Rewriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If you're looking for a reliable and affordable system for work or at home this system is perfect for you, why not have this system in your living room?
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £251.62 Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
"Titan Onyx" Intel Core i7 950 3.06GHz @ 4.00GHz Quad Core DDR3 System @ £802.21 inc VAT
The "Titan Onyx" features an Intel Core i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz. With a high overclock and DX11 graphics the "Titan Onyx" has a complete set of high end features straight out of the box. Everything you could ever want combined into one complete system.
Why Should You Buy This System?
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- DX11 performance provided from the very latest graphics cards
- 6GB of 1600MHz DDR3 Triple Channel memory allows faster loading of games and better multi-tasking
- Case: Xigmatek Asgard Midi Tower - Black
- Power Supply: Corsair CX 600W
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: Corsair H50 CPU Cooler
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Western Digital Caviar Green 2TB SATA 64MB Cache
- Graphics Card: A choice of the latest graphics cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
The "Titan Onyx" provides fantastic performance unseen at this price before. With all the features you could possibly dream of.
Was £838.21 Inc. VAT
Only £802.21 inc VAT.
ORDER NOW
"Titan Exodus" Intel Core i5 760 2.80GHz @ 4.00GHz Quad Core DDR3 System @ £615.55 inc VAT
The "Titan Exodus" features a Intel i5 760 2.80GHz processor overclocked and guaranteed to a stable 4.00GHz, combined with a selection of high performance, handpicked components to meet your desire for the perfect i5 gaming system.
- A guaranteed 4.00GHz performance for the price of 2.80GHz
- Choose from a selection of graphics cards to meet your performance needs
- Support is included for USB 3.0 out of the box ensuring a fast system for years to come
- Case: Antec 300 Gaming Case
- CPU: Intel Core i5 760 2.80GHz overclocked to 4.00GHz
- Motherboard: Gigabyte GA-P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Graphics Card: Choice of the latest graphic cards
- Optical Drive: 22x DVD+RW SATA Dual Layer ReWriter
Service Package
Wanting to play the latest games as they were meant to be seen? Then this system is for you. The "Titan Exodus" doesn't break a sweat playing the latest Direct X11 titles such as Battlefield Bad Company 2 and A.V.P. and Dirt 2.
Was £651.55 Inc. VAT
Only £615.55 inc VAT.
ORDER NOW
Krypton Intel Core i7 950 3.06GHz @ 4.00GHz USB3/SATA 6Gb/s Overclocked Bundle - Gigabyte @ £551.99 inc VAT
Designed by experts the "Krypton Intel Core i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte GA-X58A-UD3R (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Cooling MX-3 Thermal Compound
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £575.99 Inc. VAT
Only £551.99 inc VAT.
ORDER NOW
Argon Intel Core i3 540 3.06GHz @ 4.00GHz Overclocked Bundle - MSI @ £224.99 inc VAT
Designed by experts the "Argon Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.00GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- CPU: Intel Core i3 540 3.06GHz @ 4.00GHz
- Motherboard: MSI H55M-ED55 (Socket 1156) DDR3 Motherboard
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Cooler: Artic Cooling Freezer 7 Pro Rev2 CPU cooler
Service Package
Was £245.08 Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black @ £129.98 inc VAT
The Antec Twelve Hundred is the evolution of the best-selling Nine Hundred, expanding on its award-winning design with even more cooling, capacity, and convenience. The Twelve Hundred is incredibly robust, with 12 drive bays, 7 expansion slots, and space for even the largest graphics cards. To keep the most demanding systems nice and cool, the Twelve Hundred boasts an unprecedented cooling system, with a top mounted 200mm blue LED fan, two rear blue LED 120mm fans, and three front blue LED 120mm fans to cool the HDD cages. Factor in convenient features like front mounted USB, eSATA, and HD audio ports, and the Twelve Hundred obliterates the competition.
- 12 Drive Bays
- 7 expansion slots
- Advanced cooling system
- No power supply included
- Motherboard: Up to standard ATX
- Top mounted I/O ports for easy access
- Perforated front bezel for maximum air intake
- Washable air filters reduce dust build up in your system
- Convenient top accessory tray for a personal media player
Was £137.86 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Arctic White @ £87.98 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £94.97 Inc. VAT
Only £87.98 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 PC3-16000C9 2000MHz Triple Channel Kit (CMX6GX3M3B2000C9) @ £119.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i7 triple channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 9-10-9-27
- Pin Voltage: 1.65V
Was £126.62 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Antec High Current Gamer 400W Power Supply @ £46.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The
High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors
and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
Was £50.03 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
Corsair Dominator 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (CMP6GX3M3A1600C8) @ £119.99 inc VAT
The DOMINATOR is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair DOMINATOR only uses highly screened IC’s to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the DOMINATOR modules can even be outfitted with additional upcoming accessories with enhanced features.
- Outrageously fast 1600MHz performance
- Ultra-low 8-8-8-24 latency
- Intel XMP (Extreme Memory Profile) Support
- Includes new connector for future upgrades and accessories
- Limited Lifetime Warranty
Was £127.64 Inc. VAT
ORDER NOW
GeIL 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel (GVP312GB1600C9TC) @ £134.39 inc VAT
GeIL announces the launch of the all new DDR3 Value PLUS & Ultra PLUS Series to be added to GeILs’ high performance memory line of products. The Value PLUS & Ultra PLUS are equipped with the latest PLUS Edition memory heat-spreader designed with heat-sink surface and extended height for maximum cooling efficiency. The Ultra PLUS line of memory will be carrying over-clocking performance while the Value PLUS line has the more stability-oriented specifications. As GeILs’ quality standard, both series will be enhanced with DBT – Die-hard Burn-in Technology for the highest quality assurance.
- PC3-12800 1600MHz CAS 9-9-9-28
- 240pin, Non-ECC, Un-buffered DDR3 DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- 1.5V-1.6V Power Supply
- Lifetime Warranty
- DBT - Die hard burn-in technology (Improved reliability)
Was £139.99 Inc. VAT
Only £134.39 inc VAT.
ORDER NOW
GeIL 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel (GVP36GB1600C9TC) @ £59.99 inc VAT
- PC3-12800 1600MHz CAS 9-9-9-24
- Lifetime Warranty
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Antec High Current Gamer 520W Power Supply @ £56.99 inc VAT
Was £61.26 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
GeIL 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP38GB1600C9DC) @ £91.90 inc VAT
- Lifetime Warranty
Was £94.99 Inc. VAT
Only £91.90 inc VAT.
ORDER NOW
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) @ £38.39 inc VAT
- Lifetime Warranty
Was £41.99 Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £74.39 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £81.70 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
GeIL 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel (GX22GB6400UDC) @ £33.59 inc VAT
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 1GB and 2GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Lifetime Warranty
- 1.9V-2.3V Power Supply
Was £35.99 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Antec High Current Gamer 620W Power Supply @ £68.99 inc VAT
Was £73.52 Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
GeIL 4GB (2x2GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel (GX24GB6400C4UDC) @ £55.19 inc VAT
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 2GB and 4GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- Lifetime Warranty
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £233.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £239.99 Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £299.99 Inc. VAT
Only £287.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card with FREE MOH Game @ £143.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6850 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6850 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
This high-speed graphics card outdoes the competition with 775MHz, a 4 GHz memory clock, DP + HDMI + Dual DVI which allows for play across four screens and a shader speed of 800 to ensure that graphics are crisp and life-like.
Along with the new series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD’s HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
The AMD Radeon HD 6850 offers no compromise performance with flawless image quality so users aren’t just playing the game – they’re in it.
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Processing Cores: 960
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1x DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FREE Download of Latest Medal of Honor PC-Game when you register product with XFX, see inside packaging for download instructions
Was £151.14 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card with FREE MOH Game @ £185.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
- Core Clock: 900MHz
- Memory Clock: 4200MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £191.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI CrossFireX Ready
- ATI Avivo HD
- Warranty: 2 Years
Was £120.50 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £104.16 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Palit GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 2 years
Was £289.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Exclusive Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 768MB GDDR5
- Memory Clock: 3680MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £122.54 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 1024MB DirectCU TOP GDDR5 PCI-Express Graphics Card @ £161.99 inc VAT
- ASUS Exclusive DirectCU Thermal Solution: Three 8mm flattened copper heat-pipes contact GPU directly and reach up to 20% COOLER than generic GeForce GTX460
- Over-clocked with 775 MHz engine clock for reaching 115% performance
- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Memory Interface: 256-Bit
- Shader Clock: 1550MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £173.60 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £113.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
ORDER NOW
OCZ Vertex 2E Bigfoot 240GB 3.5" SATA-II Solid State Hard Drive @ £311.99 inc VAT
OCZ Vertex 2 SATA II 3.5” Solid State Drives deliver the same industry-leading performance as the 2.5” edition in a larger, lower cost per gigabyte form factor to easily integrate into desktop applications without the need to install additional hardware.
Designed to excel in both sequential and random read/write speeds up to 50,000 4KB random write IOPS, the 3.5” Vertex 2 maximizes productivity when used as a primary storage or boot drive, minimizing program load times and completing tasks with blazing speed. Using the latest controller technology, the 3.5” Vertex 2 provides a faster, more responsive PC experience complete with TRIM support to keep your drive operating at peak performance in Windows 7 systems. Built with SATA 3Gb/s, Vertex 2 3.5” drives easily integrate into today’s desktop platforms as the ultimate storage upgrade.
Features:-
- Max Read: up to 285MB/s
- Max Write: up to 275MB/s
- Sustained Write: up to 250MB/s
- Random Write 4KB (Aligned): 50,000 IOPS
- Available in 90GB to 480GB capacities
- Native TRIM support
- Max IOPS Firmware
- Seek Time: .1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 25.40mm (H)
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation,.5W in standby
- Shock Resistant up to 1500G
- RAID Support
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- 3-Year Warranty
Was £326.80 Inc. VAT
Only £311.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £323.99 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £347.22 Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
OcUK Cream 18.5" Widescreen LCD Monitor - Glossy Black @ £71.99 inc VAT
This OcUK Value 18.5" monitor has an industry leading ultra-fast 2ms response time making it perfect for blur-free video and gaming. With it's 2000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
- Screen Size: 18.5" Widescreen
- Resolution: 1360x768
- Contrast Ratio: 2000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 444.0mm x 324.0mm x 170.5mm
- Weight: 3.2kg
- Warranty: 3 Years On-Site
Was £81.70 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Samsung B1930N 18.5" Widescreen LCD Monitor - Glossy Black @ £89.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 50000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 250cd/m² and you have a monitor that is made for multimedia.
- Contrast Ratio: 50000:1
- Response Time: 5ms
- VESA Compliant
- Dimensions: 455.6mm x 375.0mm x 178.0mm
- Weight: 3.35kg
Was £102.12 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Samsung BX2235 21.5" Widescreen LED Monitor - Mystic Black @ £137.99 inc VAT
It’s not an illusion, each Samsung monitor’s 2-millisecond response time makes faster, clearer images a reality. No matter how quick the action gets, this monitor keeps up with the scene, delivering stunning, seamless motion imaging that enhances your movie viewing, game playing and internet streaming experience. There’s no juddering, blurring or ghosting, just smooth viewing that you can totally immerse yourself in. With Magic Speed, finally magic you can believe in.
There’s dynamic and then there’s Mega Dynamic. With an upgraded contrast ratio – the highest level of contrast ratio currently available - Samsung monitors deliver professional picture quality that makes colours more rich and real then you’ve dreamt possible. So real, you’ll see each eye-popping colour and crystal-clear detail come to life right on your screen.
Why should seeing the whole picture be a stretch, or for that matter, a distorted facsimile of the original? With Samsung’s intelligent adjustable image size function, you’ll be able to enjoy images exactly as they were intended, by portraying standard sized content in its original format, on a wider screen.
Magic Eco makes saving energy easy. It adjusts Samsung monitor’s brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off’. If Magic Eco is turned off, you still enjoy the option of using Samsung’s Magic Bright feature, engineered to let you manually adjust the screen’s brightness. Take the effort out of saving energy and take control with Magic Eco.
Samsung Monitors aren’t just high performers. They’re eco-friendly, efficiency experts as well. The automatic off timer allows users to save energy by setting the monitor to turn itself off at a specified time. As an added benefit, this ensures optimal performance for lasting reliability and extended life.
Magic Angle creates the perfect viewing position when you are lying down. By recreating the image purity that you see when viewing the screen from the front, Magic Angle makes entertainment more comfortable. When returning to a normal viewing position, Magic Angle should always be turned off to ensure ocular comfort.
Samsung’s innovative custom key feature puts enhanced entertainment at your fingertips, literally. By allowing you to assign your favourite function to the customised key, your favourite features are accessed in a flash. Will your customised key bring you Magic Bright, Magic Colour, Colour Effect, or the Image Size function? The beauty is, you decide.
Enhance images your way using Samsung’s advanced ColourEffect feature. Open your eyes to a completely customised viewing experience as you play with photographic effects that match your mood. Choose from Aqua, Sepia, Green and Greyscale to interact with your display in a whole new way – namely, yours.
Features:-
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 500000:1
- Weight: 3.55kg
Was £143.99 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
ViewSonic VP2365wb 23" Premium IPS Panel Widescreen LCD Monitor @ £203.99 inc VAT
The VP2365wb is one of ViewSonic’s new LCD Professional Series monitors that utilizes the power of IPS panel technology. With IPS true colours, high contrast ratio and wide viewing angles coupled with 1920x1080 Full HD resolution, the VP2365wb is the perfect solution for designers, manufacturers, medical applications and movie production. A 4-port USB hub for cluster free connectivity, ergonomic functions with pivot, height adjust, tilt, swivel and slim bezel make the VP2365wb a feature-packed monitor.
- Screen Size: 23" IPS Widescreen
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 14ms
- Viewing Angles (H/V): 178°/178°
- 4-Port USB 2.0 Hub
- VESA Compliant
- Dimensions: 548.0mm x 433.0mm x 250.0mm
- Weight: 6.8kg
Was £215.99 Inc. VAT
Only £203.99 inc VAT.
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £146.39 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Was £153.18 Inc. VAT
Only £146.39 inc VAT.
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £177.59 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Was £183.82 Inc. VAT
Only £177.59 inc VAT.
ORDER NOW
Sony VAIO F12 MOE/B 16.4" True HD LED TFT Intel I7-740QM, 4GB DDR3, 500GB HDD, Blu-Ray, NVIDIA GT330M, Win7 Home Premium 64-Bit @ £881.99 inc VAT
Just like the Z-series, the F12 packs a boatload of impressive specifications, but rather than cramming them into as small a chassis as possible, this 16.4in laptop - measuring 263 x 41 x 387mm and weighing 3.1kg - sits firmly in the desktop replacement category. Gamers aside, it has plenty of power to be most consumers' primary machine. At its heart is an impressive 1.73GHz 740QM Intel Core i7 quad-core CPU which turbo-clocks to 2.93GHz. This is backed by 4GB of DDR3 RAM, which is as much as most users will need and plenty for the supplied 64-bit Windows 7 Premium to be happy with.
For storage there's a generous 500GB hard drive that spins at a speedy 7,200rpm, while optical duties are handled by a Blu-ray drive. Combined with the screen's 1,920 x 1,080 resolution and an Nvidia GeForce GT 330M graphics card, this makes for a very capable multimedia machine that should also have a modicum of gaming ability.
Connectivity is also well up to speed. For wireless duties we have Wi-Fi N and Bluetooth 2.1, with the always-appreciated addition of a physical wireless switch. There are three USB 2.0 ports, one of which doubles as an eSATA connector. Then there's a four-pin mini FireWire port, which is becoming quite the rarity these days.
Other data ports, including USB 3.0, can be added through the laptop's 34mm ExpressCard slot, while two separate memory card readers take Sony's proprietary MS Pro and the more common SD/MMC card formats. Finally for video we have HDMI and analogue VGA, while audio is handled by 3.5mm headphone and microphone jacks, the former of which doubles as an optical digital output.
This stunning Sony Vaio F2 series laptop gives you a top of the range performance on all your computing and multimedia tasks.
Bypass booting up and get online instantly with one touch of the 'WEB’ button. Multi-task easily on the large 16.4in HD (1920 x 1080) display, which is also perfect for spectacular viewing of high-definition movies via the built-in Blu-ray drive. An up-to-date Intel Core i7-740QM processor and 4GB memory give you a great performance every time - multitask or play your favourite games knowing your laptop won't grind to a halt. The glistening black finish and slimline design mean this Sony Vaio F2 series laptop is as stylish as it is powerful. A 500GB hard drive gives you plenty of storage place for all your MP3s, photos and files. Stay in touch with friends and family across the world via Skype using the built-in webcam and microphone. Organising your favourite photos and videos has never been easier - now you can create professional-looking movies to share with family and friends in just three easy steps.
A new 'ASSIST' button gives you instant access to Vaio Care, with help easily available to recover and restore files and to diagnose or troubleshoot your Sony Vaio F2 series laptop.
Features:-
- 3D Mark 2006 Score of 6750 points (Ideal for Good Gaming Experience)
- Intel Core i7-740QM processor (Upto 2.93GHz Turbo Mode)
- 4GB DDR3 RAM
- 500GB 7200RPM hard drive
- 16.4in Vaio HD display (1920 x 1080; 16:9)
- Blu-ray Disc ROM drive with DVD SuperMulti
- NVIDIA GeForce GT 330m GPU graphics
- 802.11 a/b/g/n
- Built-in Motion Eye digital camera
- Bluetooth 2.1+ EDR
- Gigabit Ethernet
- HDMI & VGA Connections
- 3-in-1 Card Reader
- Weight: 3.1kg
- Windows 7 Home Premium
- Brand new sealed product, full 2yr Sony Warranty
Was £969.19 Inc. VAT
Only £881.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I5-460M, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,018.80 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Core i5-460M 2.53GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i5 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i5-460M 2.53GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
- - 3D Mark 2006 Score of 12750 points (Ideal for Maximum Gaming Experience)
Was £1,078.80 Inc. VAT
Only £1,018.80 inc VAT.
ORDER NOW
Cooler Master Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) @ £11.99 inc VAT
Cooler Master's Hyper TX series has evolved with requirements of current mainstream CPUs. The introduction of Hyper TX3 marks another milestone with Cooler Master's first-ever full compatibility with Intel LGA 1156 socket.
Hyper TX3 is taking basic ideas and simple design while incorporating it with most of the fine points of a decent performing cooler, such as the flexibility to switch from Intel to AMD quickly and easily, the dual fan design to attach another 92mm fan to increase the cooling power. Hyper TX3 also brings back the "original" direct contact heat-pipe design from Cooler Master.
- Flexible mountings for Intel Socket LGA 775/1156 and AMD Socket 754/939/940/AM2/AM3.
- Maximum compatible CPU wattage: over 130W TDP.
- 3 x Direct Contact heat-pipes with aluminum fins to provide excellent heat dissipation.
- Option for adding 2nd fan to increase cooling performance.
- New 92mm PWM fan with wide RPM range and anti-vibration rubber pads.
- Silent CPU cooler at only17 dBA (at minimum speed).
- Easy swappable fan by clips (clips for 2nd fan included).
- Excellent airflow design with compact heatsink dimension.
Was £13.26 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £96.98 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Only £96.98 inc VAT.
ORDER NOW
MSI X600 Ultra Thin 15.6" WLED TFT, Intel SU4100, 4GB RAM, 500GB HDD Windows 7 Home Premium - Black @ £418.80 inc VAT
MSI has launched a new laptop to meet the ever-increasing demands of our mobile needs. The unveiling of its brand new line of ultrathin notebooks is a milestone both technologically and aesthetically. This innovativly-thin laptop has completely revolutionized the idea of a portable computer; its sleek yet simplistic lines fit seamlessly into its polished exterior, raising the bar for thin-notebook design a step higher.
The design of the X600 strives to be literally, as light as a feather, and, as thin as one too. Its near weightlessness and ultra thin exterior has fused graceful design and trendsetting style. Perhaps the most stunning aspect of this laptop is that in entirety, it weighs a mere two kg. It is undoubtedly the world’s lightest and thinnest 15.6-inch laptop. The X600, although thin, has not compromised its technology in the slightest; it is precision design, down to the last detail.
The X600 embeds ATi Mobility Radeon HD 4330 3D graphics card with 512 MB VRAM, providing support for millions of colors, brilliant detail and breathtakingly vivid effects. The 15.6-inch LCD widescreen glossy display makes watching high definition DVDs or gaming a real pleasure, as it brings you one step closer to your viewing experience.
The 16:9 theater ratio can provide bigger visual area. When watching movies, the black bars on the top and bottom of the 16:10 aspect ratio screen can also be avoided. This is perfect for playing HD videos at any possible angle, absolutely ideal for visual enjoyment.
The X600 is embedded with LED power-saving backlight technology to provide better color fullness and brightness, elevating the total quality of imagery. Furthermore, the lower usage of power can offer a longer operating time.
MSI exclusive VIVID technology is able to display signals that allow for richer colors, making the X600 has one of the most stunningly dramatic screens on the market, bringing even the smallest details to life. Regardless of whether you’re gaming, editing images, or simply watching movies, your experience will be incredibly realistic.
Features:-
- Intel SU4100 1.30GHz Processor
- 4GB of Memory
- 500GB HDD
- 15.6” 16:9 Wide Screen Display (1366*768)
- The Very Best Expression of Slim Aesthetic
- ATi Mobility Radeon HD 4330 Graphics Card with 512 MB VRAM
- MSI Exclusive EDS (Ergonomic De-Stress) Keyboard
- Advanced Power Saving Technology
- Theater Class 4 Speakers Qualified by Latest Dolby® Surround
- WiMAX™ Wireless Module (optional)
- HDMI (High-Definition Multimedia Interface) Output
- Built-In High Resolution Mega Pixels Webcam
- 802.11b / g / n Wireless Lan with Bluetooth (optional)
- 6 Cell Battery (upto 8hr battery life)
- 2 years Warranty
Was £478.80 Inc. VAT
Only £418.80 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 250GB SATA-II 8MB Cache - OEM (ST3250318AS) @ £26.95 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 250GB of high-performing, eco-friendly digital storage.
- Capacity: 250GB
- Cache: 8MB
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £28.58 Inc. VAT
Only £26.95 inc VAT.
ORDER NOW
MSI X340 Ultra Thin 13.3" WLED TFT, Intel SU4100, 2GB RAM, 320GB HDD Windows 7 Home Premium - White @ £335.99 inc VAT
The X340 has ingeniously applied fashionable curves in its design which successfully abandoned the cold and lifeless vibe of the traditional notebook computers. The material is gentler to the touch compared the metal, and the paint finish is glazed and UV processed, added with the perfect ratio as a total package, creating the most simplistic yet modern styling, fitting for the most contemporary trend anywhere. With all these unique features, it proves that the X340 is not only a fashionable and appealing notebook computer; it also set very high marks for the entire industry. These great reasons are why the X340 should be highly recommended to all of the contemporary metropolitans anywhere. The X340 has selected the 13 LCD display as oppose to the 12” or even smaller sizes. This provides much more comfort in reading and operation as well as less weight restraints compared to the 14 models. The 16:9 theater ratio can provide bigger visual area. When watching movies, the black bars on the top and bottom of the 16:10 aspect ratio screen can also be avoided. This is perfect for playing HD videos at any possible angle, absolutely ideal for visual enjoyment. The X340 is embedded with the LED power-saving backlight technology in providing better colour fullness and brightness, elevating the total quality of imagery. Furthermore, the lower usage of power can offer a longer operating time. The Vivid Technology can enhance the richness in colours from the source of the signal so the images displayed can provide more levels and details. This also gives a more three-dimensional expression during gaming, watching movies or viewing pictures, and even during the editing process. X340 is also equipped with the exclusive ECO Engine power management system, so you can select freely from the five different modes suitable at your convenience. The five modes include office, gaming, movies, presentation, and turbo battery. Through varies conditions such as the brightness of the screen and standby timeframe, the power consumption can be much more flexible, providing more hours of operating time. This escalates the productivity of the X340 as well as convenience for our users.
The X340 features the latest Intel Centrino Processor Technology, which uses Intel Core2 Solo ULV Processor and Intel GS45 + ICH9M-SFF Chipset, to deliver long battery life, innovative mobile solutions with unrivaled processor performance, stunning new HD capabilities, and great wireless connectivity (Integrated WiFi+ optional WiMAX, up to 450mbps 802.11 b/g/n). HDMI Digital Terminal Interface offers more than 5 GB of transmitting bandwidth; it also lessens the complications of cables. The X340 offers the very best in image quality through the HDMI Terminal so it may have the most realistic picture perfection. The X340 is embedded with a high pixel webcam incorporated with the design of the notebook for a slick and technological appearance. The user may broadcast live during teleconferencing, capturing and recording every exciting moment. Great quality and richness in colours when taking photos both indoors and out adding even more excitement. The X340 is also embedded with the IEEE 802.16e WiMAX(Worldwide Interoperability for Microwave Access)wireless module, which highly elevated the variety of wireless internet service, allowing the online experience to be faster and more mobile. Regardless if you’re in the coffee, shops, school campuses, offices, or airports, you may access the world through WiMAX, never missing the latest information. Other than the WiMAX feature, the X340 also processes the 802.11b /g/n Wi-Fi wireless internet access, so you can have all the internet functions fulfilling a mobile lifestyle. The X340 also provides Bluetooth capability which can be connected to cellular phones, earphones, PDA, and other gadgets, say goodbye to the fuss of lines and cables forever. The X340 has provided a complete entertainment interface which includes a 2 in 1 card reader (supports SD/MMC), varies mainstream memory sticks, making it easy inputting data into the notebook computer. Also applicable to many digital products such as digital video and photo cameras, MP3 Players and others, which can all be connected to the X340 Pro through USB 2.0 port. External DVD Burner is also available (optional) so you can play DVD movies or burn important documents
Features:-
- 2GB of Memory
- 320GB HDD
- 13.3” 16:9 Wide Screen Display (1366*768)
- Intel GMA 4500MHD Graphics
- 4 Cell Battery (upto 8hr battery life)
- 2 years Warranty
Was £408.50 Inc. VAT
Only £335.99 inc VAT.
ORDER NOW
Dell Inspiron 1011 Intel Atom N270 1.60GHz 10.1" LED, Mini Netbook (Obsidian Black) - Windows 7 @ £197.99 inc VAT
Timing is everything, and now you can have all the time in the world. The newly designed Inspiron Mini 10 offers up to 8.5 hours of battery life to keep you on the go. This Dell Inspiron Mini Netbook features a 160GB hard drive, plenty of room to store all your photos and music. It also features a webcam so you can communicate with friends or family from miles away, or use it to take images of yourself to upload on to the net. If you're looking for a small, lightweight, great quality Netbook for general web browsing, emailing and keeping your photos safe then the popular Dell Mini Inspiron Netbook is for you!
- Intel Atom N270 1.60GHz Pineview Processor
- Display: Built-in 10.1" WSVGA TrueLife widescreen display (1024 x 600)
- 1GB RAM
- 160GB Hard Drive
- 3 in 1 Card Reader
- 3 Cell Battery
- 3x USB2.0
- Windows 7 Starter
- 12 Months Warranty
Was £229.78 Inc. VAT
Only £197.99 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Was £255.31 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Iiyama ProLite E2607WS 26" Widescreen LCD Monitor - Black @ £227.99 inc VAT
The new flagship product from Iiyama is the E2607WS, a High Definition, 2ms 26” LCD solution perfect for today’s demanding applications. Superb colour quality is achieved by a 4000:1 Advanced Contrast Ratio. The OptiColour features allows quick and simple adjustment of the colour settings to suit the application or mood. 5 Watt speakers offer Stereo Audio performance well above the average multimedia display available today. The three input configuration of HDMI, DVI and Analogue guarantees compatibility with the flexibility to switch between multiple sources.
- Screen Size: 26" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 4000:1
- Viewing Angles (H/V): 170°/150°
- Dimensions: 597.5mm x 460.5mm x 238.0mm
- Weight: 8.3kg
Only £227.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 500GB SATA-II 16MB Cache - OEM @ £29.16 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 500GB
- Cache: 16MB
- Warranty: 3 Years
Was £30.62 Inc. VAT
Only £29.16 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £41.03 inc VAT
- Capacity: 1TB
- Cache: 32MB
- Warranty: 3 Years
Was £43.91 Inc. VAT
Only £41.03 inc VAT.
ORDER NOW
Hitachi Deskstar 7K2000 2TB SATA-II 32MB Cache - OEM (0F10311) @ £91.19 inc VAT
The Deskstar 7K2000 hard drive delivers a colossal two terabytes of storage capacity and 7200RPM performance in a standard 3.5" form factor. Now in its fourth-generation, the 7K2000 is based on a robust mechanical design that continues to set the industry standard for quality and reliability. The Deskstar 7K2000 offers an exceptional blend of capacity and power efficiency, with idle power savings over previous generation products up to 10%. On a watts per gigabyte basis, idle power has improved over 120%. Leveraging eighth-generation power management technology, including power-saving innovations like HiVERT technology, this drive delivers best-in-class power management and thermal emissions to help manufacturers meet energy compliance targets and extend drive life.
- Capacity: 2TB
- Cache: 32MB
- Warranty: 3 Years
Was £96.98 Inc. VAT
Only £91.19 inc VAT.
ORDER NOW
Western Digital Caviar Green 1TB SATA-II 64MB Cache - OEM (WD10EARS) @ £43.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 1TB
- Cache: 64MB
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £45.95 Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £76.99 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 5 Years
Was £79.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £68.99 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Was £71.48 Inc. VAT
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £24.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £26.54 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard @ £60.67 inc VAT
The GA-880GM-UD2H introduces revolutionary Gigabyte Ultra Durable 3 Classic technology on AMD platform featuring a 2oz copper PCB and further helps to reduce the system temperature and dramatically enhance the performance. Based on AMD 880G chipset, the GA-880GM-UD2H is integrated ATI Radeon HD 4200 (DX10.1) graphics engine and supports AMD Phenom II quad-core processors, DDR3 memory modules, HyperTransport 3.0 technology links, PCI Express 2.0 graphics interface and more. With the innovative Gigabyte Easy Energy Saver technology, GA-880GM-UD2H is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- CPU: AMD Phenom II/Athlon II Series Processors (Socket AM3)
- Chipset: AMD 880G / SB710
- System Bus: Up to 5200 MT/s HyperTransport 3.0
- Memory: 4x DDR3 DIMM 1800(OC) / 1666 / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Integrated ATI Radeon HD 4200 GPU
- Expasion slots: 1x PCIe 2.0 x16 Slot, 1x PCIe x1 Slot & 2x PCI Slots
- Storage: 1x Ultra DMA 133/100/66, 5x SATA 3Gb/s (RAID 0, 1 and 10) & 1x eSATA 3Gb/s
- LAN: RTL8111D Gigabit LAN
- Audio: ALC892 8-channel High Definition Audio CODEC
- 12x USB 2.0
- 2x IEEE 1394a
- 1x PS/2 COMBO (Keyboard & Mouse)
- 1x S/PDIF Out (Optical)
- 1x HDMI
- 1x DVI
- 1x D-SUB
Was £71.47 Inc. VAT
Only £60.67 inc VAT.
ORDER NOW
Asus Rampage III Extreme Intel X58 (Socket 1366) DDR3 Motherboard @ £276.98 inc VAT
Asus Republic of Gamers reveals the latest addition to their roster of performers, the world-record shattering Rampage III Extreme. Delivering Intel's X58/ICH10R chipset with support for the Intel processors in the LGA1366 package up to six cores and a plethora of features demanded by intense users, this board is the only choice for PC speed demons. Remote tweaking becomes effortless thanks to built-in ROG Connect and RC Bluetooth, giving users the freedom to unchain true hardware potential. Rampage III Extreme contains the latest iteration of Extreme Engine Digi+ voltage modulation technology for purer, more stable power. The OC Kit strikes a formidable pose as an interface to meet the strenuous requirements of even the techiest overclocker, with LN2 mode and a Q reset that addresses cold boot problems and enables fast operation even under very low temps during extreme overclocking.
- 2x USB 3.0
- 2x SATA 6Gb/s
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express / ICH10R
- Memory: 6x DDR3 DIMM 2200(OC) / 2133(OC) / 2000(OC) / 1800(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 4x PCIe 2.0 x16 Slots, 1x PCIe x4 Slot & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA 3-Way SLI Technology)
- Storage: 7x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 1x eSATA 3Gb/s
- LAN: Intel Gigabit LAN
- Audio: 8-channel High Definition Audio CODEC
- Bluetooth V2.0/V2.1+EDR Card
- 9x USB 2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- Extreme Engine Digi+
- USB BIOS Flashback
- ROG Connect
- ROG Extreme OC Kit
- Extreme Tweaker
- iROG
- ProbeIt
- ASUS Q-LED
- Loadline Calibration
- Q-Fan Plus
- ATX (305.0mm x 269.0mm)
Was £296.15 Inc. VAT
Only £276.98 inc VAT.
ORDER NOW
Gigabyte GA-X58-USB3 Intel X58 (Socket 1366) DDR3 Motherboard @ £120.00 inc VAT
Based on the Intel X58 chipset, the Gigabyte GA-X58-USB3 delivers all the killer next generation features that gaming enthusiasts and power users have been waiting for including Gigabyte's 333 Onboard Acceleration features with support for USB 3.0 and a 3x USB Power Boost, as well as multi-GPU support for NVIDIA 3-Way SLI and ATI CrossFireX and support for Intel's high performance processors offering a high level of future CPU headroom for users wanting to maintain cutting-edge levels of performance. With the memory controller integrated directly into the processor die, the Gigabyte GA-X58-USB3 also supports triple channel DDR3 memory for blazing fast memory performance.
- 2x USB 3.0
- Memory: 6x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 1x PCIe 2.0 x16 Slot (running at x4), 3 x PCI Express x1 slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 8x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- Audio: ALC889 8-channel High Definition Audio CODEC
- 6x USB 2.0
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
Only £120.00 inc VAT.
ORDER NOW
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard @ £142.25 inc VAT
This motherboard supports the latest Intel Core i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. The P6X58D-E breaks the boundaries to bring you the multi-GPU choice of either SLI or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability.
- Memory: 6x DDR3 DIMM 2000(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 1x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Coaxial)
- 16+2 Phase Power Design
- TurboV
- MemOK!
- EPU
- Express Gate
- Fanless Design
- Stack Cool3+
- CrashFree BIOS 3
- EZ Flash 2
- MyLogo 2
Was £153.05 Inc. VAT
Only £142.25 inc VAT.
ORDER NOW
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard @ £99.98 inc VAT
This motherboard supports the latest Intel Lynnfield and Clarkdale processors, which have the memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes, enabling higher graphics performance. Supporting the next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0Gbps data transfer rates. Experience ultra-fast data transfers at 5Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10 times faster and is also backward compatible with USB 2.0 devices. Turn on IO Level UP to boost the USB 3.0 or SATA 6Gb/s data transfer rate to up to 500MB/s. Users can flexibly switch between full-speed PCIe x16 mode for their graphics cards and IO Level UP for rapid data throughput.
- CPU: Intel Core i7/Core i5 Processors (Socket LGA1156)
- Chipset: Intel P55 Express
- Memory: 4x DDR3 DIMM 2200(OC) / 1600 / 1333 / 1066 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 3x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Ultra DMA 133/100/66, 7x SATA 3Gb/s (RAID 0, 1, 5 and 10), 2x SATA 6Gb/s & 1x eSATA 3Gb/s
- LAN: RTL8112L Gigabit LAN
- Audio: VT1828S 8-channel High Definition Audio CODEC
- 2x IEEE 1394a
- 12x USB 2.0
- 2x USB 3.0/2.0
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- TurboV EVO
- T.Probe Technology for Active Cooling
- ASUS 12+2 Phase Power Design
- Quad-GPU CrossFireX Support!
- MemOK!
- EPU
Was £108.24 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Thermaltake Frio CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £36.98 inc VAT
The Thermaltake Frio has excellent cooling capacity supporting 220W with 0.5mm aluminum fins that have a large surface for heat dissipation. It's 5x U-shaped copper heat pipes provide accelerated heat conduction through this tower side flow designed cooler.
It efficiently optimizes cooling performance with 120 mm VR fans, adjustable between 1200 and 2500 RPM max. for best overclocking performance. As well as being universally compatible it comes with some premium thermal grease to maximize heat transfer from the CPU into the cooler copper base for rapid dissipation
- Ultimate Overclocking Thermal Structure Design
- Ultra Powerful Dual 120mm VR Fan and Eye-Catching Cover
- Universal Socket Compatibility & Accessory Package
- Supports up to 6 Core Processors
- Socket Compatibility: LGA1366/LGA1156/LGA775/AM2/AM2+/AM3
- Fan Speed: 1200 - 2500 RPM
- Air Flow: 101.6CFM
- Noise Level: 20 - 43 dBA
Was £39.82 Inc. VAT
Only £36.98 inc VAT.
ORDER NOW
"Primo Trinity" Intel Pentium Dual Core E6500 2.93GHz DDR3 System @ £229.99 inc VAT
The "Primo Trinity" features the excellent value Intel Pentium Dual Core E6500 2.93GHz processor, combined with a selection of high performance yet excellent value, handpicked components designed to meet your desire for the home office or work system.
Why You Should Buy This System?
- The Dual Core E6500 is perfect for multi-tasking applications in the home or office environment
- Small and silent making it the ideal home office or work system
- Large capacity 500GB hard giving you plenty of room for storage
- Precision built and cabled by Overclockers UK expert technicians
System Specification
- Case: OcUK Hades Micro ATX Case
- Power Supply: OcUK Value 450W Power Supply
- CPU: Intel Pentium Dual-Core E6500 "LGA775 Core 2" 2.93GHz
- Motherboard: MSI G41M-P25 Intel G41 (Socket 775) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 Dual Channel
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Onboard Intel GMA X4500 Graphics
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: 22x DVD+RW SATA Dual Layer Rewriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If you're looking for a reliable and affordable system for work or at home this system is perfect for you, why not have this system in your living room?
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £251.62 Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
"Titan Onyx" Intel Core i7 950 3.06GHz @ 4.00GHz Quad Core DDR3 System @ £802.21 inc VAT
The "Titan Onyx" features an Intel Core i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz. With a high overclock and DX11 graphics the "Titan Onyx" has a complete set of high end features straight out of the box. Everything you could ever want combined into one complete system.
Why Should You Buy This System?
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- DX11 performance provided from the very latest graphics cards
- 6GB of 1600MHz DDR3 Triple Channel memory allows faster loading of games and better multi-tasking
- Case: Xigmatek Asgard Midi Tower - Black
- Power Supply: Corsair CX 600W
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: Corsair H50 CPU Cooler
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Western Digital Caviar Green 2TB SATA 64MB Cache
- Graphics Card: A choice of the latest graphics cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
The "Titan Onyx" provides fantastic performance unseen at this price before. With all the features you could possibly dream of.
Was £838.21 Inc. VAT
Only £802.21 inc VAT.
ORDER NOW
"Titan Exodus" Intel Core i5 760 2.80GHz @ 4.00GHz Quad Core DDR3 System @ £615.55 inc VAT
The "Titan Exodus" features a Intel i5 760 2.80GHz processor overclocked and guaranteed to a stable 4.00GHz, combined with a selection of high performance, handpicked components to meet your desire for the perfect i5 gaming system.
- A guaranteed 4.00GHz performance for the price of 2.80GHz
- Choose from a selection of graphics cards to meet your performance needs
- Support is included for USB 3.0 out of the box ensuring a fast system for years to come
- Case: Antec 300 Gaming Case
- CPU: Intel Core i5 760 2.80GHz overclocked to 4.00GHz
- Motherboard: Gigabyte GA-P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Graphics Card: Choice of the latest graphic cards
- Optical Drive: 22x DVD+RW SATA Dual Layer ReWriter
Service Package
Wanting to play the latest games as they were meant to be seen? Then this system is for you. The "Titan Exodus" doesn't break a sweat playing the latest Direct X11 titles such as Battlefield Bad Company 2 and A.V.P. and Dirt 2.
Was £651.55 Inc. VAT
Only £615.55 inc VAT.
ORDER NOW
Krypton Intel Core i7 950 3.06GHz @ 4.00GHz USB3/SATA 6Gb/s Overclocked Bundle - Gigabyte @ £551.99 inc VAT
Designed by experts the "Krypton Intel Core i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte GA-X58A-UD3R (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Cooling MX-3 Thermal Compound
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £575.99 Inc. VAT
Only £551.99 inc VAT.
ORDER NOW
Argon Intel Core i3 540 3.06GHz @ 4.00GHz Overclocked Bundle - MSI @ £224.99 inc VAT
Designed by experts the "Argon Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.00GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- CPU: Intel Core i3 540 3.06GHz @ 4.00GHz
- Motherboard: MSI H55M-ED55 (Socket 1156) DDR3 Motherboard
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Cooler: Artic Cooling Freezer 7 Pro Rev2 CPU cooler
Service Package
Was £245.08 Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
