How to move 200kg from portsmouth to Brighton?
It's no problem providing the guy can put in on a pallet and secure it with a strap? You'd be looking at a price of around £70 for item to be delivered within 4days max.
Also the bench should weigh more then 10kg if its good quality. My powertec one is 30kg and came in 2 parts.
The bench is very high quality.
£70? The value of the kit sort of goes down. Will end up paying £220 in total if this is the case, which seems to expensive. Guess i'll just have to look closer to home. Damn I hate waiting. Bet I'm going to be looking in a months time. ¬_¬
Two logs.
It may take some time.
I considered the train, but then thought your suggestion would be probably save me a mortgage.
Seriously, how expensive are trains?
If the train station could promise to look after my stuff and wait a minute or two for me to unload all the stuff, it might be worth a trip. They are such ******** in Brighton I can't see it happening...
Erm don't be ridiculous. A bench will easily fit in a normal car - sure you have to put the seats down, but that's purely owing to the length of it. And 200kg in a car is absolutely fine - cars can cope with a lot bigger load than 200kg (I'd be screwed otherwise every time I took 1 passenger ;)). I've moved more than that in 306.
306 estate maybe, but not a hatchback
lol
190kg of weights and a high quality bench would be worth around £700 brand new
I live in portsmouth and will deliver it to you for money :) I dont have uni till next week just a lot of work i like to put off.
Will send you a mesage in trust. :)
lol
Hmm that does put a different spin on things. God know why I want 190kg of weights when I weigh only 75kg myself haha. I'm guessing motivation ;)
Haha, would certainly be a workout if nothing else. :D
Taxi's? :eek: Surely they most cost hundreds?
Not sure, I was thinking your airport type taxi firms, I dunno if they have a specific name. But they must get luggage + 2\3 passengers from A to B quite often. And they usually do things for set cost, rather than a running clock.
I live in Portsmouth but the rest of my family are based in Brighton. I would gladly help you out but I doubt I'm going back to Brighton for atleast 2 weeks. If nobody else can help drop me an email!
It's a Infiniti bench. Sounds okay, but in reality I have no idea :p
tbh i would leave the bench, its worth about £20 second hand.
the weights 190kg, as long as they are olympic, are worth £275+ brand new (depends on they type and make, some can be worth £1K+), second hand £190+ assuming they aren't special in any way, just standard olympic plates.
Friend/family with a car of decent size. I had 500kg worth of passengers last night, was absolutely fine.
