HTML Image rotation, stuck
28 Sep 2008
Britain
Guys, stuck here and it's winding me up.
I have a web page, the main header is a group of images that rotate using JS. I now want to add another small group of images to one of the webpages which rotate too. I assumed that I could use the same JS code but the new group of images also shows the main header group rotating. So, I changed all the variable names in the script and that hasn't worked either.
Here is my JS
Code:
var imgShowSpeed = 3000
// Duration of crossfade (seconds)
var crossFadeDuration = 3
// Specify the image files
var Pic = new Array() // don't touch this
// to add more images, just continue
// the pattern, adding to the array below
Pic[0] = 'images/top.png'
Pic[1] = 'images/top1.png'
Pic[2] = 'images/top2.png'
// do not edit anything below this line
var t
var j = 1
var p = Pic.length
var preLoad = new Array()
for (i = 0; i < p; i++){
   preLoad[i] = new Image()
   preLoad[i].src = Pic[i]
function runImgShow(){
   if (document.all){
      document.images.ImgShow.style.filter="blendTrans(duration=2)"
      document.images.ImgShow.style.filter="blendTrans(duration=crossFadeDuration)"
      document.images.ImgShow.filters.blendTrans.Apply()
   document.images.ImgShow.src = preLoad[j].src
   if (document.all){
      document.images.ImgShow.filters.blendTrans.Play()
   j = j + 1
   if (j > (p-1)) j=0
   t = setTimeout('runImgShow()', imgShowSpeed)
var slideShowSpeed = 3000
Pic[0] = 'images/top.jpg'
Pic[1] = 'images/top1.jpg'
Pic[2] = 'images/top2.jpg'
Pic[3] = 'images/top3.jpg'
Pic[4] = 'images/top4.jpg'
Pic[5] = 'images/top5.jpg'
Pic[6] = 'images/top6.jpg'
Pic[7] = 'images/top7.jpg'
var t
var j = 1
var p = Pic.length
function runSlideShow(){
   if (document.all){
      document.images.SlideShow.style.filter="blendTrans(duration=2)"
      document.images.SlideShow.style.filter="blendTrans(duration=crossFadeDuration)"
      document.images.SlideShow.filters.blendTrans.Apply()
   document.images.SlideShow.src = preLoad[j].src
   if (document.all){
      document.images.SlideShow.filters.blendTrans.Play()
   j = j + 1
   if (j > (p-1)) j=0
   t = setTimeout('runSlideShow()', SlideShowSpeed)
And here is my HTML
Code:
<script type="text/javascript" src="scripts\imagerotatefade.js"></script>
</head>
<body onload="runImgShow()";"runSlideShow()">
<div id="wrapper"><!--start wrapper-->
<div id="topbar">
<img src="images/top.png" alt="" name='SlideShow' />
</div>
<div id="header">
<!--start header--><img src="images/top.jpg" alt="" name='ImgShow' /></div><!--end header-->
I'm not sure if you can grasp what I'm wanting to do here but hope someone can help. Thanks
Sorry I can't help you but can I see this on your website? I need an image rotator but I have no idea how it all works...!
I dont have it live yet but its dead simple to get the one set working.
You need a script file. Call it imagerotatefade.js
In there, put this code:
Code:
var t
var j = 1
var p = Pic.length
   if (document.all){
   if (document.all){
   j = j + 1
   if (j > (p-1)) j=0
You only need to change the Pic array stuff with the numbers and names of your pics
Then in your HTML, you call the js script like this:
Code:
That goes before your closing /head tag.
Then, call the function in your HTML with the onLoad command like this:
Code:
<body onload="runSlideShow()">
Then, where you want the image, you call it as normal but with the name='SlideShow' command like this:
Code:
This might be a silly question, but are the rotating images on the webpage in the header as well? or on the page itself <body>? Are the divs (or tables whatever you're using) in the CSS or in the HTML, and you've changed it so that it's div#main or div#header?
Sorry if it's a daft question and I'm sure that the answer to all is the correct one!
You've not changed enough variables! :)
The first definition of Pic, preload, t, j and p are being overwritten by the second definitions of them.
Easy fix. change the ones you copied to Pic1[0], preload1 etc.
Thanks, so do I need to change t, j and p to other things too?
So i have pic0[1], pic1[2], etc, and then just preload1?
everything you copied into the top, you will need to modify.
so
var t
var j = 1
var p = Pic.length
and then anywhere in the top bit that contains those variables
for (i = 0; i < p1; i++){
preLoad1 = new Image()
preLoad1.src = Pic1
j1 = j1 + 1
if (j1 > (p1-1)) j1=0
etc.
here is your top bit changed for you:
Code:
var imgCrossFadeDuration = 3
var Pic1 = new Array() // don't touch this
Pic1[0] = 'images/top.png'
Pic1[1] = 'images/top1.png'
Pic1[2] = 'images/top2.png'
var t1
var j1 = 1
var p1 = Pic1.length
var preLoad1 = new Array()
   preLoad1[i] = new Image()
   preLoad1[i].src = Pic1[i]
   if (document.all){
      document.images.ImgShow.style.filter="blendTrans(duration=imgCrossFadeDuration)"
   document.images.ImgShow.src = preLoad1[j1].src
   if (document.all){
   j1 = j1 + 1
   t1 = setTimeout('runImgShow()', imgShowSpeed)
so
var t
var j = 1
var p = Pic.length
preLoad1.src = Pic1
j1 = j1 + 1
etc.
ok cool, so now I have this as the second part of the JS file:
Code:
var crossFade = 3
Pic1[0] = 'images/top.jpg'
Pic1[1] = 'images/top1.jpg'
Pic1[2] = 'images/top2.jpg'
Pic1[3] = 'images/top3.jpg'
Pic1[4] = 'images/top4.jpg'
Pic1[5] = 'images/top5.jpg'
Pic1[6] = 'images/top6.jpg'
Pic1[7] = 'images/top7.jpg'
var t1
var j1 = 1
   if (document.all){
(duration=crossFade)"
   document.images.SlideShow.src = preLoad1[j1].src
   if (document.all){
   j1 = j1 + 1
   t1 = setTimeout('runSlideShow()', SlideShowSpeed)
SlideShowSpeed should be slideShowSpeed
and try this instead add to the bottom of the script file:
Code:
function runAll(){
t1 = setTimeout('runSlideShow()', slideShowSpeed)
then change
Code:
to
Code:
<body onload="runAll()">
Works here.
Ok, you know how this is like two scripts in one file, do I have to put it twice or do I just remove the end / start half way through as top images rotate, bottom ones still don't :(
I really appreciate your help here though, so thanks so far :)
Html Page
Code:
<html>
<head>
<script type="text/javascript" src="1.js" >
</script>
</head>
<div id="topbar">
<img src="images/4.jpg" alt="" name='SlideShow' />
</div>
<div id="header">
<!--start header--><img src="images/1.jpg" alt="" name='ImgShow' /></div><!--end header-->
</body>
</html>
JS
Code:
Pic[0] = 'images/4.jpg'
Pic[1] = 'images/5.jpg'
var t
var j = 1
var p = Pic.length
   if (document.all){
   if (document.all){
   j = j + 1
   if (j > (p-1)) j=0
var crossFade = 3
Pic1[0] = 'images/1.jpg'
Pic1[1] = 'images/2.jpg'
Pic1[2] = 'images/3.jpg'
var t1
var j1 = 1
   if (document.all){
      document.images.SlideShow.style.filter="blendTrans(duration=crossFade)"
   if (document.all){
   j1 = j1 + 1
function runAll(){
Wow, cool, it works. Thanks.
The only thing you had different was that in the HTML my 'SlideShow' and 'ImgShow' were round the other way.
Thanks again
