- 24 Nov 2002
- 38.744281°N 104.846806°W
Man with a van. Usually £40-50 per day + mileage.
tbh i would leave the bench, its worth about £20 second hand.
the weights 190kg, as long as they are olympic, are worth £275+ brand new (depends on they type and make, some can be worth £1K+), second hand £190+ assuming they aren't special in any way, just standard olympic plates.
The bench is very high quality.
£70? The value of the kit sort of goes down. Will end up paying £220 in total if this is the case, which seems to expensive. Guess i'll just have to look closer to home. Damn I hate waiting. Bet I'm going to be looking in a months time. ¬_¬
£220 for 190kg of weight on its own is very good price. If you don't want it feel free to send me the contact details / advert, i'd happily have it (as long as its oly weights)![]()
306 estate maybe, but not a hatchback
It's no problem providing the guy can put in on a pallet and secure it with a strap? You'd be looking at a price of around £70 for item to be delivered within 4days max.
Also the bench should weigh more then 10kg if its good quality. My powertec one is 30kg and came in 2 parts.
LOL! Ok whatever you say matey.
It will fit in a hatchback easy with the seats down.
this clearly is not a fixed bench that has stands stuck up etc etc.
ive seen the advert and pics, i doubt the thing would fit in an estate, the bench has a lat pulley attachment and other stuff too. it isnt olympic weights either and the equipment is mostly crap.
OP: better off joining a gym (a lot cheaper than building a home gym) or doing some research here http://forum.bodybuilding.com/forumdisplay.php?f=26 if you really wanna go down the home gym route
if you buy cheap crap, you cant do a proper workout and if your really into weight lifting you will outgrow it within 3 months, meaning you wasted your money.
the minimum you would need for a decent setup:
rack (minimum £300 new) - mines was £750 including attachments
bench (minimum £200 new) - mines was £430 including attachments
olympic weights and bar (minimum £200 new) for 100kg +bar
matting (2 horse stall mats - £80 minimum) - 2 is just to start with, you will need more if you want to do deadlifts and other stuff outside your rack.
so i suggest you just join a gym and if in 6 months time you really want a home setup try and get the above second hand, even second hand you would be lucky to knock off 25-35% from the above. and this is bare minimum you would need to spend.
Worst "I spent a lot of money on weights" post ever.
Believe me thats nothing, it can get very expensive building a commercial home gym. I'll be flogging my set up later on this year, feel sorry for anyone picking it up in a car, I have well over a ton in Olympic plates and dumbbellsWorst "I spent a lot of money on weights" post ever.
.Believe me thats nothing, it can get very expensive building a commercial home gym. I'll be flogging my set up later on this year, feel sorry for anyone picking it up in a car I have well over a ton in Olympic plates and dumbbells.
Don't worry I'll be sure to drop one or two hints on here. Just imagining 60 kilo dumbbells for you and the 5 kilo dumbbells for your little boy.If you are being good with the prices let me know first, could do with some more stuff![]()
