- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Get yourself the amazing new midi tower case from Corsair. Stock is not arriving until April, we will be taking orders from March.
Corsair Obsidian 650D Gaming Midi-Tower - Black *** ARRIVING IN APRIL *** @ £145.99 inc VAT
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.
- Motherboard Support: ATX / mATX
- Expansion Slots: 8
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
Only £145.99 inc VAT.
We will be taking pre-orders from March.
