This thing is massive and blunt-ended, so I have no idea how it managed to penetrate the tyre
I'm guessing that a puncture of this size isn't repairable (the diameter of the bolt must be about 0.75cm)? That'll be £400 down the drain for 2 new tyres
It's so long that I'm worried about whether it might have damage the rim too.
Surely not? I would have thought if you were intending to damage tyres you would use something a bit sharper?Starting to wonder whether it had purposely been stuck upright to the road.
It damaged both tyres? That's a long bolt!
I knew that sentence wasn't quite right when I was writing itsnigger
True, I just have no idea how something like this could go from lying flat on the road to being embedded in a tyre.Surely not? I would have thought if you were intending to damage tyres you would use something a bit sharper?
It might aswell have, there's no way I'm driving around with tyres of different tread depths on the same axel.It damaged both tyres? That's a long bolt!
This thing is massive and blunt-ended, so I have no idea how it managed to penetrate the tyre(
Yeah, because that would be lethal!![]()
I've known people to leave them in as its plugging the hole its made, rather get it removed and repaired personally!
Couldn't have left this one in, the head is so big that the car was pretty much undriveable.
Runflats though so atleast I can drive to the tyre fitters![]()
