- 11 Oct 2005
- Doncaster
Ok I posted a request about this issue in the technical queries section on this forum back on the 24th Nov last year. I have left 3 separate messages regarding this issue 24/26th November & last on the 24th of December and not had 1 single reply to any so I will ask in here.
I purchased the Akasa duo dock 2
The system I am using it on at the moment is an old Gigabyte GA-X38-DQ6 which uses these esata brackets
These
1st of all it took a re-format of windows to get 1 drive to be noticed, but even then it took 5mins to even appear in windows. I then tried just leaving it turned on then rebooting which seemed to work the drive was noticed straight away but soon as you turned the Akasa off and turned it back on again the pc needed another reboot before the drive could be noticed again.
I have 1 bracket in at the moment the brackets themselves consist of 2 sata cables which are plugged into the purple sata slots on the motherboard and also plugged into a molex.
Yes I am happy with the duo dock working but it’s not working to its full potential! it will work with 1 drive in but still has troubles seeing the drive when you turn the unit off and back on again.
Though the main problem now is that whenever you put 2 drives into the duo dock only 1 drive will be recognized no matter what you try 2 drives will not work together only 1 will be seen inside windows, even in the BIOS it only recognizes 1 drive.
I am personally not happy at the moment because overclockers have seemed to have ignored my request for help. I haven’t had the time over Christmas to phone but I am back home in 2 weeks and will then be on the phone to support about this issue I don’t know if it’s a issue with these silly esata brackets on the gigabyte board or if there is a problem with the duo dock itself.
Thanks for any help.
These
