- 28 Aug 2008
I have an old Dell XPS m1530 (T8100, 3Gb, 8600m GT) and while it's still working fine, it's starting to feel really sluggish compared to other desktop/laptop systems I've used lately - particularly when using VMs for work and the odd bit of gaming. I know I could potentially upgrade the RAM (and the OS which is Vista 32-bit flavoured) but I think it's just time to hand it down and move on.
I've been googling my ass off and browsing forums (such as this one) and still haven't really picked anything that meets all my criteria. Essentially, I spend most weeks working away from home and so need a laptop that is comfortable and reasonably quiet for use in customer environments whilst being able to run a few games (EVE, WoW, CoD games etc) at decent framerates (without having to set everything to low). I guess my criteria is something like:
Does such a thing even exist? I suspect I'll have to compromise in a few areas but the fewer the better.
Ones that came close with comprises so far are:
Any other ideas?
Oh and as for budget.. preferrably under £2k. And it should be a Windows machine - I'm not averse to Apple products but I just want to head off any software compatibility issues down the line.
TIA
MP
- between 13 and 15.6" screen
- not overly thick/heavy (i know this is probably subjective but I spend many hours a week lugging my laptop around airports etc)
- higher res than the usual 1366x768 which may be fine for gaming but is a bit weak for work - conversely 1920x1080 screens might cause issues when running games at the native res - something like 1600x900 seems to be a good compromise
- doesn;t look like a something designed by Tomy found in your local Toys R Us.
- I5 or i7 with at least 6Gb ram
- decent GPU for gaming - perhaps not top end but at least capable of running most modern games at decent levels
- couldn't care less about speaker quality or optical drives
- at least 500Gb 7200rpm drive (or SSD+320Gb or above)
- doesn;t sound like a steam engine on crack during non-gaming activities
- Sony Z-Series - very portable, very good specs but awesomely expensive and concerned that the 330M with a 1080p screen will just kill any ideas of gaming.
- Acer Aspire Ethos 5943G - fits the bill in so many ways but let down badly by the low res screen (and I read somewhere that Acer screens can be a bit meh)
- Toshiba Satellite A665 - again great spec but the low res lets it down.
- Dell XPS 15 with the i7/2Gb GF 435M but you can either select a 1366x768 or 1920x1080 resolution - the former is a bit low, the later perhaps a bit much for the 435M when gaming?
- MSI GX660/Alienware M15x - both well specced but both very plastic and absolutely hideous.. I'd be fairly embarassed taking either out of my bag in a business meeting
Any other ideas?
TIA
MP
