New Intel System Advice
30 Dec 2010
Cloud 9
Hi guys
Well iv changed my mind from going to AMD 6x and now going to be buying the following but would like to know if you would change anything ?
CPU 2500k Upon Release
Motherboard / http://www.overclockers.co.uk/showproduct.php?prodid=MB-432-AS
RAM / http://www.overclockers.co.uk/showproduct.php?prodid=MY-295-CS
PSU / http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-CS
Case / http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM
Cooling / http://www.overclockers.co.uk/showproduct.php?prodid=HS-003-CS
Will the H70 Water Cooling fit to the type of Motherboard and will everything else go together well for overclocking ?
I'm not sure if the 1155 socket has been released as of yet
for the h70. but the Titan fenrir evo is also very good.
what graphics card you going to use?
just checked fits same as the 1156 settings but will might need a wriggle. what is overall budget?
the case is a personal choice.
A smaller psu would suffice likethe 650w, If you have the money and have any thoughts of xfire then id just stick with the 750w. Good first choice anyway :)
Iv just ordered my 2500k now so no going back now lol.
I will take your advice and go down to the 650 PSU save a few extra £'s
