Crysis Mods
You have to download EQM and use the flowchat/config from that if you want it in single player. I'm trying to get these maps as a .cry file though so i can spawn some enemies in sandbox2, however I've somehow just corrupted SB2 and so am now reinstalling crysis :s. I tried downloading a .cry file pack, but I just got an 'invalid path' every time i tried to open it in SB2. So once I've downloaded Crysis/SB2 again, I'm going to try and compress the map into a zip and then rename the .zip to .cry
I take it you need the sandbox editor for that? I've never messed about with flow charts before but don't mind giving it a go and learn something new. Is it easy to learn?
did you install those maps into your levels folder?
Was wondering if you fancy seeing if we can get multiplayer working on it
w00t I've finally managed to get the map into sandbox 2 as a .cry file. Will update shortly on how well adding enemies goes.
Yessss I can now spawn enemies into that map. I'm gona work for a while on making a really cool bunch of enemies and then see if I can export it into a file that can be loaded up from in-game.
Got it all working now, can load up the map from in-game with all the enemies I've put into it. Just had a really fun game where I spawned about 30 asian soldiers into it, 3 trooper aliens, and 1 hunter. So it was a real deathmatch. The soldiers killed 2 alien troopers, i killed one. The troopers took out a couple soldiers before they died. The rest of the soldiers got devoured between me and the hunter. I picked up a missile launcher one of the soldiers dropped and killed the hunter, then finished off the soldiers.
Was huge fun :D
I'm going to make three variations of the spawns on the map, one with just solders, one with just aliens and one with both for all out war :D Might also make one with Jester as company :p If anyone wants me to send them the file once I've done it so they can have some single player deathmatch fun in an awesome looking map (map not made by me), then let me know.
Was huge fun :D
Id like a copy once its done please, sounds a lot of fun thanks.
After reading this thread, I've decided to get the hi def foliage mod. Not sure about the other mods, considering real lifesis, but I think that the natural mod looks really good anyway.
The hi def foliage mod makes even the standard game with no mods whatsoever look much better let alone with other mods installed. You will see a big difference!
just a note on the realifesis mod. The config tweak screws up the later game, when it's all icy and the aliens are flying around you can't see them in the sky at all. The flying section is made extremely difficult because everything is also made too bright, and the final fight on the ship is unplayable because it causes all kinds of problems.
You can set what format it uses in the autoexec.cfg.
Or use XnView, or IrfanView, to convert the tga's to jpg.
